FE Power Forums => FE Technical Forum => Topic started by: olman on September 27, 2018, 09:28:54 PM
for lubing up the valve stems after a valve job?
I just use a very light coating of motor oil. Valve stems see very little oil when running, especially with positive seals, so no need to go with a heavy lubrication like you'd use on bearings and such.
Thanks for the info Doug!
Agreed. I tend to use oil on pretty much everything. No magic elixirs or special powders here.
So you are not a fan of Total Seal Quick Seat?
Thanks again- Barry I just bought your book last month and am really enjoying the information, a lot that I never knew about(well maybe a whole lot). Bud
A solution looking for a problem
Hahaha! Lot of truth there...
