FE Power Forums => FE Technical Forum => Topic started by: Thumperbird on August 08, 2018, 08:15:48 AM
Title: Holley Twins Question
Post by: Thumperbird on August 08, 2018, 08:15:48 AM
All,
I am wanting to buy a second set of carburetors for my dual quad 445 in the heavy 65 Thunderbird.
Currently have a set of bj/bk's on it and tweaking those but would like a spare set so I can always have something in operating condition and also have the ability to compare one set to the other.
Dual quad so they have to be single side feed, also feeling like 4 corner idle adjust might be a good fit for the Edelbrock dual quad air gap with custom offset spacers, not sure yet.
Considering a generic set of Holley 01850SA's or Quick Fuel SL-1957E's or ?
Looking for suggestions on best way to go?
Thanks.
Title: Re: Holley Twins Question
Post by: Falcon67 on August 08, 2018, 11:15:45 AM
Why not Ed 600s.  I bolted a pair on a 302 tunnel ram and they did fine.  One I had, the other was a $100 eBay purchase.  Set both to box stock and they had decent AFR readings and basically drove out the door.  I did do tweaking with pump shots and calibrate to get best launch and MPH at the drag strip, but I was pretty impressed for just throwing two carbs on a mild 302 and lighting it off.
That said, I have a pair of decent older 1850s and the plan would be to use Drew's calibration data to set those up for test.  But that would be tested on a not-so-mild 351C with a tunnel ram, 4.56 gear and 4800 stall converter.  Without Drews data, I would have torn down one of the Eds and used some measures for a baseline start.  Basically, the Eds ended up 4% fatter primary/secondary on both the get best MPH on the track so I would have taken the base 1850 setup and looked for 4%, or maybe start one jet size all around which can be as much as 3%, depending.
One big difference is that the Eds have a very efficient primary booster system and a smaller primary bore/venturi.  "Spreadbore" like. The 1850s, not so much.  So idle and drive-away for a street car would be where you'd likely need most tweaking.
Post by: Drew Pojedinec on August 08, 2018, 11:41:43 AM
Thanks Chris. I didn’t want to be the guy to suggest edelbrocks.
I mean, yeah I could build some 1850’s, but that isn’t gonna solve the distribution issues.
Post by: e philpott on August 08, 2018, 11:53:03 AM
Someone like Keith Craft or FE Specialties ( can't remember who ) just posted a dyno result from the EBrock intake with EBrock carbs and were pleasantly surprised how well they did on Wes's Face book a few weeks ago
Post by: Drew Pojedinec on August 08, 2018, 12:22:27 PM
Yup was Lance Smith of Craft Performance engines.
600hp out of a 462 I think.
Post by: Thumperbird on August 08, 2018, 12:50:10 PM
Not sure how bad the distribution is just yet.  One data point, i.e. bj/bk makes it tough as I do not have experience or other reference for jsut how smooth or strong the combo can/should be.
I get a decent idle around 700, not too bad for the combo I believe, but a tad rough cold.
Currently working on moderate and hard acceleration lean out.
Not a bad idea to try Ed's, no custom spacers of course, will have to check out that article.
Not that I really care too much but they just do not have the same look one expects on a Ford.  Kind of still want to stay somewhat close to real 1960's ford world.  If I want to stray more I would go EFI for fun I think.
I have found a couple used 600 vacuum secondary Holleys I can pick up for $50 a piece, might just play with them as well.
Are the Quick Fuels worth the extra $'s in my application if I decide to go with a new set of carbs?
Other models?
Post by: Drew Pojedinec on August 08, 2018, 03:21:27 PM
If ya want....  send me the repro bj/bk’s. I’ll record the calibration and test them out on my 2x4 setup.
Won’t cost you anything but shipping.
If they don’t run right for me, we can make some changes as you see fit.
Post by: Thumperbird on August 08, 2018, 04:07:07 PM
Thanks for the offer Drew, might take you up on that this winter.
I have not tested and tweaked enough yet myself, part of the reason is that it is too much fun to drive so I don't want any down time.  With the duals, it takes extra effort to make internal carb changes.  Having another set would at least enable me to swap and go more or less.
I will track all of my changes as I go here, heck i haven't even played with it using a single carb yet.
I need to get my final exhaust in place and a pvc in the mix, getting a bit of oil out of the breathers at higher RPM's.
I also think I need to lower converter stall by 3 to 400 rpm's, too soft down low for my taste but not sure how much of that might be tune.
Post by: Pentroof on August 13, 2018, 06:29:40 PM
Holley Twins? Never heard it put that way. Maybe that's why I started thinking about Holly Sonders.
Now every one of you is going to Google that.....admit it!
Post by: Heo on August 14, 2018, 08:33:22 AM
I did ;D ;D
Post by: My427stang on August 14, 2018, 09:12:48 AM
Thumpr, I'd consider Drew's offer because assuming your carbs are good, they are likely the best running carbs for your application (assuming the adapters aren't causing the issue)
It'd be real nice to see what a sharp carb guy with a dialed in engine sees with yours, then you can either have him fix yours, or you can rule out the carbs.
I don't remember what your adapters look like, but it wouldn't take much cause some turbulence around the corners.  You likely posted before, but do you have any pics?
Post by: machoneman on August 14, 2018, 09:43:12 AM
Holly Twins?
Here you go!
https://www.youtube.com/watch?v=noYmDgLZfYI
Post by: Barry_R on August 14, 2018, 10:13:50 AM
Let Drew check the carbs.  I suspect that - if the carbs are OK - you are fighting that manifold spacer deal.
Post by: Thumperbird on August 14, 2018, 07:48:46 PM
I will probably send to Drew this winter if I don't feel good enough about things.
Current state:
Rich at idle, rich at tip in, I think as soon as the second carb comes on just a tiny bit things get lean, get into it a little more and not bad, then moderate to heavy acceleration goes quite lean.
What is good is that I can sit at a light for several minutes or more in 95 degree heat and it just keeps chugging along, no overheat, very minor changes in rpm occasionally, but rich.
As I said earlier, getting exhaust done soon and a few other things so the platform is more stable for tuning.
Have not had them off yet to give a once over, too many not so fun summer obligations.
Thanks for input.  Will post spacer picture again when I find it.
Post by: Thumperbird on August 15, 2018, 08:19:25 AM
Spacer Images
Post by: Drew Pojedinec on August 15, 2018, 08:36:57 AM
Well those are interesting. Don’t look as bad as I’d have thought in regards to the angle.
I am interested in them being made from plate vs one whole piece.
I’d be interested in vacuum testing them. One lil air leak can cause havoc.
Do you still mount the carbs backwards?
Post by: Thumperbird on August 15, 2018, 08:50:49 AM
Carbs are forward, primary is in the back though.
They are sealed well at all plate interfaces, don't think that is an issue but when I pull the carbs will double check.
Spent an hour or so on the spacers blending all internal edges to nice radii, same for intake.
1" 4 hole sits above them.
About a 48 degree angle, 1" rise over 1.125" run for the offset portion.
Thanks.
Post by: Thumperbird on August 15, 2018, 09:32:18 AM
Better picture of whole setup.
Post by: e philpott on August 15, 2018, 09:46:29 AM
You need to let Drew run them on his test engine , that will answer the question on Carbs
Post by: Drew Pojedinec on August 15, 2018, 10:25:13 AM
Cool, so carbs face forward and primary carb is astern.
That puts the primary Venturi in the middle and away from that 90 degree turn.
Should be ok that way. Interesting. I need to buy one of those intakes and play with it.
Post by: wayne on August 15, 2018, 04:48:51 PM
offenhauser part 5880 will put holleys on your intake summit racing has them.
Post by: Drew Pojedinec on August 15, 2018, 04:58:06 PM
Wayne, they already are on.
Post by: Thumperbird on August 15, 2018, 08:39:10 PM
Did not know those existed, they only provide an inch of spacing though, you need over 2 inches to put twin Holleys on a Edelbrock Air Gap.  Maybe one could stack 3 of them?
Post by: My427stang on August 16, 2018, 09:23:12 AM
First, your work is beautiful, no critique here, just trying to see why there might not be max power out of these
Although there could be some odd turbulence in the plenum, I don't see this setup being a problem unless you ended up with way too much plenum and fuel is falling out of suspension or there are sharp edges inside causing shear
It could be a carb issue,  still think getting them on something else may be beneficial, but would hate to see you spend a lot of money on carbs if that wasn't the issue.
Also, have you tried wiring the scoop open?  Wouldn't affect much sitting still, but never know what some odd airflow across the tops of carbs will do, and with the butterflies moving with the linkage, who knows what is happening in there
Grasping a bit, but things to consider
Post by: cjshaker on August 16, 2018, 10:27:01 AM
Just an untrained observation, but with both carburetor airflow streams aimed at each other, where they'll at least partially collide, then get pulled in another direction, I would think that would cause some serious fuel suspension issues. In other words, I'd think the airflow pattern with those spacers is all messed up. It only takes one fat cylinder to make an O2 sensor read rich. If fuel is puddling and getting sucked into 1 or 2 cylinders, then cleans up a bit at different flow rates, that's gonna make an O2 sensor give erratic readings. No amount of carb tuning will cure an issue like that. Just maybe something to consider.
Post by: Thumperbird on August 16, 2018, 01:00:05 PM
I do see a slight improvement in mixture with scoop removed but not much.
This setup, while reverse from traditional and of course acknowledging the spacers, is not all that much different in relative location of carbs to each other and to the manifold than OE.
Does anyone know what the average velocity is for air in any one intake runner at say 5000 rpm's in a stroker?  Are there any high frame rate videos of clear FE intakes fed with colored air to try and see just how much turbulence is in there and where?
Thanks.
Post by: Heo on August 16, 2018, 01:30:53 PM
A neighbour had a GTX or Roadrunner or somthing like that
with a Tunnelramed 440 with a scoop like that
When he removed it he saw a big inprovment in performance
i think it was around one sec ET and a bunch of MPH
Post by: cjshaker on August 16, 2018, 02:13:30 PM
It's the spacers I'm talking about. An OE setup is not comparable because of them. I'm not saying they are the problem, just saying they could be. Intake and head porting is all about directing airflow. Because of the spacers, the airflow actually has to reverse direction on itself to reach the front and rear ports. I can't see that as being good.
Post by: Pentroof on August 18, 2018, 04:57:55 PM
I don't understand why you added 1" straight spacers and didn't use that height to straighten out the angle of the custom spacers? Why not make your custom spacers taller with less angle?
Post by: Thumperbird on August 19, 2018, 08:06:42 PM
Jim
Had to make the call between carb signal or possible lack thereof and the angle of the spacers/volume right under the carbs.  I felt like, just a guess really, that the 4 hole would be more valuable in providing a stable base for the carbs signal wise, yes at the expense of geometry.
Also, since I was making the spacers at home with a chop saw and table saw and wanted it running this spring, time was tight, I could not make something more fancy in terms of a taller spacer with less slope but with some internal structure, that may be this winters project.  Been thinking about a 4 tube spacer but I need to retain the spray bars.
Like I said, I am not sure how much trouble the spacers are causing, have not had enough time to tweak the carbs yet.  I need to get some more fuel in at WOT and see how it behaves.  It is already incredibly thirsty but oh well.
Until I know more about just what the flow is doing I am going to stay on the carb side of things for tuning for now, hard to believe there is a ton more turbulence in there than normal setups at higher rpm's.  It is very smooth at cruise rpm's between 2000 and 3500 rpms.
