FE Power Forums => Non-FE Discussion Forum => Topic started by: Katz427 on June 30, 2018, 03:32:46 PM
Well , this is not an FE, instead AFR heads on 351 SBF. The valve stem seals are gone after about 1200 miles. Looks like many did not stay seated on the guide and consequently were destroyed.
Anyone have a preference for the stem seals?
I buy Viton seals from US Seal in bulk, but if they didn't stay put, and were the right size for the guide, I would look close to make sure the inner spring isn't hitting them or your retainer design isn't hitting at max lift.
I don't believe the heads were touched, basic AFR package of springs, seals, retainers. I will check . Just checking comments on AFR and Summit racing, a few have had the problem.
