FE Power Forums => Member Projects => Topic started by: Royce on June 06, 2018, 08:38:05 AM
https://bringatrailer.com/listing/1957-ford-fairlane-500-convertible-2/ (https://bringatrailer.com/listing/1957-ford-fairlane-500-convertible-2/)
I haven't seen it, but for sure that's a high riser intake on there, which means high riser heads. Good bet its a 427. Go for it, Royce!
If it had a Y block I would be on it...What would I ever do with Hi Riser parts? lol
I like it, looks so much lighter and sportier with cut open rear wheel wells
could have been done nicer though
I figured the mixing of styling ques was just a Minnesota aesthetic
What will it go for?
Currently the engine is worth more than the high bid. (5hr to go)
Anybody know what it sold for?
Says Reserve Not Met at 8700.
With 40 seconds left I had thoughts of bidding 9 grand but didn't know if Royce had the high bid at the time. I need another project like I need a kick in the jewels.
Should have told you guys I was not in.. I bet the reserve was probably much higher. Sure had some good parts, but to me they do not work together that well.
