FE Power Forums => Non-FE Discussion Forum => Topic started by: 427HISS on April 08, 2018, 04:06:45 PM
Going to buy a new set of engine pulley's, alternator only. I want to try the 6 or 8 rib serpentine system.
I've had March's before but not CVF's.
Any paticular reason's for choosing one company over the other ?
CVF pulleys are good quality, Midwest made and cheaper. But cant go wrong with either.
I've only used March and they fit perfect. That said next time I would definitely try CVF for the price.
CVF is about 40 bucks less. The brackets are almost the same.
Top is CVF
Until The March brothers moved to Florida, they were a local outfit. I knew them, not well, but their stuff is absolutely top-notch. And they are good guys. They make stuff for all makes, but they're FORD people. That's good enough for me!!
Good to know. $40 isn't enough not to buy. I can look, but do you know if CVF is made in thr USA ?
Yes it is US made, all of the cnc machine of pulleys and brackets.
Going to try the CVG.
I have used CVF pulley's on 3 cars now 351w 69 stang 429 83 f100 and 2v crank pulley only for added power steer on 66 fairlane only thing i didn't like is when you use a full set they always slipped and howled due to the high polish it dose go away over time but still not a nice sound on start up. Last set i taped up and did a lite sandblast of the v on each pulley worked a treat no unwanted screaming belts on start up and no need to use that spray grip that makes a mess of every thing.
The March's I've had have always been hard anodized.
