FE Power Forums => Non-FE Discussion Forum => Topic started by: 427HISS on March 25, 2018, 05:55:59 PM
Title: How To Safely Remove Paint Over Anodizing ?
Post by: 427HISS on March 25, 2018, 05:55:59 PM
I purchased a stack injection from s FE'er, which he painted the throttle bodies. I planed on painting them my cars body color which is blue.
As I was taking apart the T/B, I noticed under the paint was blue anodizing !
So, how can I remove the paint without damaging the anodizing ?
Title: Re: How To Safely Remove Paint Over Anodizing ?
Post by: Katz427 on March 26, 2018, 01:21:01 PM
Anodising is just soooo thin, best too use a heat gun. Then maybe some lacquer thinner, almost everything aggressive enough too soften the paint will attack the anodising to some degree.
Post by: 427HISS on March 26, 2018, 01:57:22 PM
I assumed so. I can't think of a mild produce that could be used safley ?
I wonder about some of the non-solvent cleaners ?
Post by: Heo on March 26, 2018, 03:20:59 PM
Brake fluid is pretty mild dont know how
it is on anodizing but i think it can take
brakefluid. it solve the paint in a couple of days
Post by: wowens on March 26, 2018, 03:56:38 PM
Try some citrus based paint remover on a scrap anodized part. If it doesn't hurt it, then try it on the paint. Guessing .
Post by: 427HISS on March 26, 2018, 07:36:23 PM
Few good ideas.
Post by: Cyclone Joe on March 26, 2018, 10:26:39 PM
You can always have it re-done if it gets messed up.  I know on gold anodize acetone and IPA applied to a rag and then wiped on it didn't seem to affect it.
Joe
Post by: gt350hr on March 27, 2018, 11:09:05 AM
 Anodizing is an electro chemical coating process. Only a caustic chemical like oven cleaner or something with acid will bother it . Brake cleaner , carb cleaner , non caustic paint removers etc will remove the paint and as long as you don't "rub" on the anodizing , it will not be affected. Since the anodizing process etches the aluminum it is often used to help paint adhere to aluminum parts besides inhibit corrosion ( it's main purpose).
Post by: 427HISS on March 29, 2018, 02:35:00 PM
Great information.  I'll look into it.
