FE Power Forums => Non-FE Discussion Forum => Topic started by: 427HISS on February 12, 2018, 06:30:06 PM
Title: Help With Garage Air Compressor Filter/Reg/Desiccant System.
Post by: 427HISS on February 12, 2018, 06:30:06 PM
I'm looking to replace my old Binks filter/regulator for my 60g upright air compressor and single stall garage.
I need one for both oiling tools and a clean line with air dryer filter/drain for painting, but, I could delete the oiler as I can just oil the tool before use.
A friend of mine does not,....use a dryer, he just buys the cheap $2 bucks for the through away desiccant filters then puts them in the garbage. He never gets water in his HVLP gun, thus not in his paint primed car. I don't know about that. lol.....It's not like I'm painting a entire car but, I want to paint my new FE block, steel bell and trany, other car parts to my honey-do-list of painting the house shutters, chairs etc.....
My use is just diy mechanic & some small piece painting garage, not everyday use. I have just a single stall garage, with a two post car lift for my Ford 427 Shelby Cobra (rep) my truck and wifes 300M.
I'd like to stay under $125 if possible. I don't want some piece of sh☆☆, yet wanting quality, low price and longivity. I know most of the time in life you get what you pay for but,....there are also great products at great prices as well. Harbor Freight has good tools and bad as well as Sears, Home Depot, Lowes, ebay, and dedicated air compressor/pneumatic tool companys....etc.
I don't want a piece of crap though. You know,.....the best of all worlds.
Here are just a few I've looked at.
Milton 1108 1/2" Filter and Regulator Duo.
$95
https://www.amazon.com/Milton-1108-F...2%3A2661618011
CH Campbell Hausfeld PA2085 Air Cleaner Dryer Filter Regulator & Lubricator.
$65
https://www.ebay.com/itm/CH-Campbell...-/332541763854
Eastwood
$30 to $1,000
https://www.eastwood.com/shop-equipm...nd-dryers.html
PNEUMATICPLUS
$45 to $88
http://www.pneumaticplus.com/pneumat...kaAk5MEALw_wcB
Selection on ebay.
https://www.ebay.com/sch/i.html?_fro...lator&_sacat=0
427HISS is offline  Report Post
Title: Re: Help With Garage Air Compressor Filter/Reg/Desiccant System.
Post by: 427HISS on February 13, 2018, 01:00:34 PM
You-Hoo....
Post by: FERoadster on February 13, 2018, 04:09:39 PM
I bought one of the HF filter descicant units and install it on a seperate line from my compressor. (downstream from my initial regulator and seperator). Seems to work OK for Plasma cutting and painting. BUT !! the HF desiccant bulb leaks a minor bit so the desiccant material will absorb water from the leak overnight and be saturated. I installed  a valve in front of it and only use it for Plasma cutting and painting.
You can bake the dessicant in an oven to dehydrate and reuse it.
Desiccant material can be costly but I did some searching and asking at various stores and found thet Wall Mart sells a small package for drying flowers. Thinking it further I tried various stores like Michaels and Hobby Lobby. Hobby Lobby sells a 5 LB bag for about $15 where at other retailers its $15 to $30 for 8 oz.
Just my findings
BTW I have 3 large tanks hooked to my compressor (5HP IR30)  and store over 250 gallons. The dessicant comes off the last tank in the stream so most watter would be settled out in the first 2 tanks.
Richard >>> FERoadster
Post by: cjshaker on February 13, 2018, 06:44:41 PM
Every link I clicked on got a "not available" page, except for Ebay.
Post by: wowens on February 13, 2018, 08:09:45 PM
http://motorguard.com/air_2_2.html
Plug this on the end of your air hose. 25' of new hose after. Use only when painting. Replace filter after 20 hrs air passing through it.
Post by: wowens on February 13, 2018, 08:24:29 PM
http://motorguard.com/air_2_4.html
Replacement filter. Forgot this last pist.
Post by: 427HISS on February 13, 2018, 10:22:20 PM
How much are they ?
Post by: FERoadster on February 13, 2018, 11:06:00 PM
The Motorgard has been available for over 30 years. I do use one for painting with an airhose coupling on the ends. But the "cheap seats" filter is to use a roll of toilet paper inside the canister. WAAAY cheaper than the "Micron" filter and every bit as effective
Richard
Post by: wowens on February 14, 2018, 08:04:46 AM
Richard, I stressed over giving that trick to him.  ;)
If you use toilet paper, buy the cheap stuff, run a good bit of air through the open line to blow out loose fibers & change often.
Post by: wowens on February 14, 2018, 08:52:01 AM
https://www.amazon.com/Motor-Guard-M-30-Submicronic-Compressed/dp/B000GI0H2M
Post by: wowens on February 14, 2018, 08:52:18 AM
Oops
Post by: wowens on February 14, 2018, 08:55:23 AM
https://www.amazon.com/Motor-Guard-M-60-Submicronic-Compressed/dp/B000WZYKAE
Post by: Falcon67 on February 14, 2018, 11:41:45 AM
The Motorgard thing is your best bet - but it'll work better if you run some iron pipe from the compressor up and along the wall(s) to your drops including drip legs.  The idea is to cool the compressed air and let the moisture condense out.  I built my own deal and it works well enough - but would add a Motorgard AND the disposable at-gun filters for car painting.  I have about 60~70' of iron pipe installed.  No filter at the blast cabinet 30' from the compressor and no water problems.  If you want an oiler for tools, then buy a filter/oiler/regulator combo and put a nipple on it so you can move it around to other drops.
(http://raceabilene.com/misc/NewShop/Air7.jpg)
Typical drop with the portable regulator setup
(http://raceabilene.com/misc/NewShop/Air12.jpg)
Post by: 427HISS on February 15, 2018, 11:56:54 AM
Chris, that is quite the muffler system on your compressor, is it to quiet it down ?
Sorry, is the pipe for the intake or exhaust ?    :o
Please tell me about it.
Post by: Falcon67 on February 16, 2018, 09:44:19 AM
The air cleaner is the intake - is does not muffle any sound.  Others claim various mods to reduce compressor intake noise but using a dB meter says it makes no difference.  The compressor is in a closet surrounded by insulation, Quiet Brace and OSB - keeps the noise down.
The tall thing is a take off of a "Frazinator".  It's a couple of long pieces of 1 1/2" iron pipe with a long 1/2 feed pipe that runs to the bottom.  The idea being that air exiting the 1/2" pipe into the larger space slows down, contacts a larger cooler surface area in the big pipe and loses some of it's moisture before entering the distribution lines.  The big pipe has a gate valve for a drain at the bottom that is plumbed out through the wall.  Air for the system exits the top.  Seems to work well enough, for general work I don't get any moisture at the working end of any lines and very little if any water in the drip legs.
The bitty gold thing is a 175 psi popoff valve to prevent a overpressure condition, as a backup to the one on the compressor.  There is now a long run to the left of the above picture that goes to the other end of the shop.  Two drops in the big parking/work area, one 50' hose reel and two drops in the tool room.
Head end
(http://raceabilene.com/misc/NewShop/Air4.jpg)
With lower pipe installed.
(http://raceabilene.com/misc/NewShop/Air5.jpg)
Full assembly
(http://raceabilene.com/misc/NewShop/Air6.jpg)
This gets used A LOT lol.  Best thing I never did for air.
(http://raceabilene.com/misc/NewShop/Air9.jpg)
Post by: 427HISS on February 16, 2018, 10:50:30 AM
"Best thing I never did for air."
Lol,.....The system looks great.
 I also used pipe for cooler air back 30 yrs ago, and I'm doing the same with the new system now.
I wish I could copy and paste my pipe and filter configuations I'm thinking of, but don't know how on this tablet.
Post by: 427HISS on February 23, 2018, 05:43:57 PM
Ok, I bought a Campbell Hausfeld 3/8" PA208503 Air Ceaner/Dryer and a PA212503AV Regulator. The price was unreal.    ;D
I plan to keep and add on, 3/4 black pipe.
Finally,...have photo's below. So, how's best to place the filters in-line and pipe run ?
The 8th pic is from a compressor manufactures website (I think,...Quincy) that is short and simple.
Is that enough or should it be longer ?
My new hose & electric reals wil need to be mounted somewhere ?
I'd like all of these to be a nice and clean install. I have a lot of man-cave stuff, neon clocks, posters etc,.......so
I don't want the pipe and other products to be a cluster f☆☆☆ mess.
Post by: 427HISS on February 25, 2018, 01:37:34 PM
Anyone.....
Post by: Falcon67 on February 26, 2018, 11:19:03 AM
I don't think you need 3/4 but it won't hurt.  I ran all mine with 1/2".  I would at least put 3/4 coming out of the compressor - flex line to 3/4 stand pipe with a drain, then up to whatever and run that line where you need it, with a drip leg at the end.  You can do the up/over with just nubs - doesn't have to be tall.  Or not - I didn't.  I would use the filters only at point of use.  I would run all the way down one side to the door and back the across the bench area with a drop on the far side near the door.  Using a hose reel at a bench is awkward, better to have a drop and use a quality coil hose for bench work.  Pipe is cheap.  Run a drop for the Max if that's its' spot, maybe one down from the hose reel by the door.  I'd also consider crossing over the ceiling for a drop on the other side - keeps you from dragging a hose across a car.  The more you can get by with a coiled hose from the filters, the better you'll like it.  Tuck the main line up as tight to the ceiling as you can, pretty soon you'll not even notice it.
Mount the hose reel where it'll do the most good.  Get some clothes line and cut it about 5~6' shorter than your hose run, tack it up and pull it around to see if it goes where you can use it.  I'd put one at least near the door beside the door tracks so it'll reach outside.
Post by: 427HISS on February 28, 2018, 08:23:43 PM
Having a long length of iron pipe, with moist air, won't you have a lot of rust ?
The same thing happens in a iron block engine and heads if it sits idle for a period of time.
Post by: 427HISS on February 28, 2018, 09:02:23 PM
Also, what if I bought or made a 2 outlet manifold, one line for air tools and the 2nd for paint ?
Post by: StarlinerRon on March 06, 2018, 11:00:40 PM
Go to tptools.com   Big free catalog with everything you need to know.
Good luck,
Ron.
Post by: 427HISS on March 11, 2018, 07:44:52 PM
I'll check them out.
Thanks.
