FE Power Forums => FE Technical Forum => Topic started by: fekbmax on January 29, 2018, 01:46:25 AM
Title: FT timing set
Post by: fekbmax on January 29, 2018, 01:46:25 AM
Is there a good timing set for the FT ?
Title: Re: FT timing set
Post by: Jb427 on January 29, 2018, 08:01:42 AM
I bought http://stores.precisionoilpumps.com/fe-ford-390-428-427-rollmaster-torrington-timing-assembly/ for my 482 build.
Post by: CaptCobrajet on January 29, 2018, 10:11:50 AM
I think I have two or three new OEM double roller chains.  If you have good gears, the chain would work.  They are .220 diameter rollers.  Modern double row stuff is .250.  I have thought about just machining the bottom gear of a .250 set.  If you put one key in it, Jay's adjustable cam gear would fix it right up.
Post by: fekbmax on January 29, 2018, 10:57:16 AM
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F272664740826
Ended up going with this, couldn't find any info on the chain, .220 v .250 . If it's a .250 then I could at least swap out the cast top gear with one of my old rollmasters . Being it's pretty much OEM it's most likely the .220 ya think ?
Post by: CaptCobrajet on January 29, 2018, 11:20:55 AM
Hard to say.  If it was manufactured recently I'd bet it is .250.  Let me know what it is when you get it.  Would be good info.
Post by: TorinoBP88 on February 01, 2018, 12:36:43 AM
Does FT have a bigger hole in lower sprocket for bigger crank diameter?
I have a couple very good stock rollers too, but FE.  Probably 0.220.
Post by: fekbmax on February 01, 2018, 07:26:53 AM
Yes,
Bigger ID on lower gear..
Post by: fekbmax on February 10, 2018, 12:33:42 PM
the enginetech set looks to be ok at least. made in US/India so it say. The chain does have the smaller .220 rollers though but i think its gonna work just fine for my needs.
