FE Power Forums => FE Technical Forum => Topic started by: Arizona ‘58Mercury on December 25, 2017, 11:43:40 AM
So living in Hell, aka Phoenix Az. For the most part the motor is stock 390 from a 65 tbird and going into a 58 Merc Monterey. Not planning on a whole lot of summer driving but even now it’s in the 60’s and 70’s. Any suggestions on radiators that flow and cool more efficiently? Thanks in advance
We were talking about this on another board.
From my experience in Las Vegas, I would a good radiator, likely 3 core if brass, 2 core if 1.25 core aluminum, as big as will fit in the space, then focus on airflow. A full shroud and a fixed fan, like the Flexalite steel or aluminum with the bent tip, as big as you can, will move a lot of air through the radiator. That should do very well for you.
It's the airflow that does it.
Okay, I will start sifting through manufacturers. Any preference brass over aluminum?
I have had 2 made thru these guys, US radiator is the mfg.
http://www.coolcraft.com/radiators/ford.html
For me that goes according to the build style because both can be very efficient.
I would think brass would be at home in a '58 Merc. Having said that I chose a cross flow aluminum for my mustang. It just fit the build style. My trucks and wagon will stay brass.
BTW I live in LA where it's slow and almost go traffic in 100 degree weather much like yours all summer.
Shroud and fan (airflow) are the keys along of course with a well working clean system.
I agree with Marc, it's all about the packaging. My F100s stock radiator works fine and allows a factory shroud and a big fan. The Mustang I went with a crossflow aluminum, but honestly, if I did it again I likely would have went with a 3 or 4 row stocker to make shroud fitment easier.
You really can't go wrong here, I'd look and see what you think will fit, maybe a big factory design off another year will allow a shroud/radiator combo that will fit with minor modification
Sounds good, thanks guys!
If using a belt driven fan, over drive pulleys will help...lot better than under drive pulleys for cooling when crawling through town.
I sometimes use a cardboard in front of my radiator when its 30-40 minus ;D
LOL
I used a 4 core aluminum radiator and derale high-output duel fan and shroud kit 16927 160 deg thermostat and davids craig fan controller.
This is over kill temps here are over 40deg C very often car runs at 170 deg F down fall is i have about 5 mm between the water pump pulley bolts and the fans and i need to remove the water pump first to remove the fan/shroud and radiator and the fans are high power draw. Did a bunch of small mods to fan shroud and radiaor to make it work in my 66 fairlane. Ill post a pic soon so you all can laugh at just how much over kill i have.
i will tell you something else to watch out for.i had the bottom rad hose suck flat when it got warm,it took a while to figure out why it was overheating.if i stopped and looked under the hood everything looked normal idling,but one day i revved the carb with the hood up and i saw something move,it was the bottom hose sucking flat every time i revved it, while driving it stayed flat under power,so use a good hose on the bottom,preferably with a spiral wire in it.
Having recently been in Phoenix, I rule you out of order. ;D i use aluminum and it gets pretty hot here. Aluminum likes hot water - 195 or better.
Like mentioned a great designed shroud can help immensely !
For my 427 Cobra I had a Griffen 600HP aluminum three core radiator, with just one large electric fan and a 195 thermostat.
Temps in our Nebraska summer will be around 90-100 ° and high humidity. In city traffic my big block would get to 130°,
when driving it would come down to 105°. I live 10 miles from the city, so after a few miles it would come downto 195 °.
To lower the temps I would remove the tnermostat in the summer.
When I built my shroud to completely surround my fan and raditor, things changed,.... almost too much. lol
The summer temps came down to 195° (great) might creep up to 205° in very hot temps traffic times.
In heat below 70° and on the highway, came down below 165°, and below 55° to under 150°, with my fan OFF.
I my not have these fluctuates in many cars, but the lenght from the nose of the car to the radiator is like a mile long.
I want to install my Cobra correct,......dual 6" fan essemble's mounted in front, of the radiator. So on hot days in traffic
I can turn them on to suck air into the radator from the front, then use the fan behind it.
Sounds,.... logical anyway. Lol .....
My long point is, get a well made aluminum (not brass) 3 to 4 core radiator and a great made shroud.
You won't regret the price. They, like anything, need to work together, or it'll be a waste of time, money and possibly your engine.
Here is all the info you need:
https://www.hotrodhotline.com/content/aluminum-vs-copper-brass-article-us-radiator
Ron Davis radiators is local to you. I had a double pass dual spahl(sp.) fan in my off road turbo car and it NEVER overheated. They are pricey, but worth it to me.
I live in Illinois and certainly don't have the summer temperatures like you do in Phoenix but I have run the same Ron Davis radiator in my '64 Galaxie NSS car for almost 15 years without problems.
I'm in the Phoenix area (Desert Hills / New River) and my '65 / 352 was my best friends daily driver for about 5 years when we were kids. Pretty sure it has a <insert your local "cheap" parts store here> sourced radiator and neither he or I ever had cooling problems with the car. This is with a simple arc of sheet metal over the ancient "flexi-fan" acting as a shroud. He drove it daily in city traffic and we spent many 100+ degree nights idling in creeping traffic while cruising Central.
I'm not suggesting that going cheap on a radiator - when I replace this one I'll probably do some sort of overkill aluminum unit - probably from Ron Davis or someone like him - but I'd be pretty surprised if a mild 390 would cause problems for an OEMish radiator if you get decent airflow through it.
Just my 2 cents... :)
