FE Power Forums => FE Technical Forum => Topic started by: bobb428 on October 25, 2017, 10:23:50 PM
Jay, what kind of thermostat do you run in your Drag Week FE's? I have the Dove adjustable housing and I am thinking its not the best for my aluminum 526" FE.
I run one of those Mr. Gasket high-flow 160 degree thermostats. I also punch 3 or 4 1/8" holes in the periphery to act as a bypass, since I'm running an electric water pump. The engine cools very well with that setup.
If you run a mechanical pump and it is rpm-friendly, do not use a thermostat. With electric pumps, Jay's method is good with a constant flow rate. With a mechanical pump, a thermostat with those holes drilled will open and close sporadically, due to the extra flow holes. A quick trip from idle to 7000 rpm when the thermostat happens to be closed will put extreme pressure in the cooling system......enough to blow all of the knock-in plugs out. Seen this more than one time. Screw-ins won't blow, but it sure is a strain on all of the seal areas. The proper Moroso restrictor ring is a good method with a mechanical pump.
