FE Power Forums => FE Technical Forum => Topic started by: funsummer on September 23, 2017, 11:55:19 AM
Title: Intake gaskets
Post by: funsummer on September 23, 2017, 11:55:19 AM
Could anyone advise on the cometic fiber intake gaskets?
I have a KC intake and head combo that was port matched to cometic gaskets.
I have just dropped off the lot to a local shop with the latest flow bench for some testing and improvement, I hope!!
Will post results as I get them.
I am aware of the issues raised in a few books ect of the fiber felpo gaskets and use in a street application.
Mine is a street application and do these fiber cometic gaskets suffer the same fate?
What is the best alternative with similar port sizes?
Joel
Title: Re: Intake gaskets
Post by: jayb on September 23, 2017, 12:55:21 PM
The Cometic gasket material doesn't blow out like the Fel-Pro Print-O-Seal gaskets do.  Use some good RTV around the water jackets and ports and you will be fine with those gaskets.
Post by: funsummer on September 24, 2017, 09:09:12 AM
Thanks Jay
Joel
