FE Power Forums => FE Technical Forum => Topic started by: scott foxwell on September 20, 2017, 02:17:30 PM
Does anyone have the rocker stand bolt spacing dimensions for the FE heads?
TIA
I believe the spacing is 4.625 for the end cylinders, unsure of the spacing between the middle cylinders 2 and 3...
scott i got 4.640 on ends 4.970 middle with calipers since i was measuring pulleys
I did some reverse engineering last night and came up with similar numbers. Thanks.
The end ones should be the same as FE bore spacing, 4.630".
Exactly! That little light just came on... ::)
