FE Power Forums => FE Technical Forum => Topic started by: smokin427 on September 13, 2017, 11:27:23 PM
Title: On Head FE Vvalve Spring Tester
Post by: smokin427 on September 13, 2017, 11:27:23 PM
Does anyone know of a valve spring tester that I can use without removing the springs, just the rocker shafts. I have 700 lb springs on my solid roller in my 427 FE 64 Falcon Sprint
Title: Re: On Head FE Vvalve Spring Tester
Post by: jimeast on September 14, 2017, 05:20:02 AM
Not quite what you are asking for, but I think it's an eloquent, inexpensive solution to removing and installing your springs.  Looks like an FE guy designed and manufactures this.  Maybe someone on the forum knows him.
http://www.ebay.com/itm/Valve-Spring-Compressor-Ford-FE-390-427-428-Cobra-Jet-Mach-1-Shelby-/263193719838?hash=item3d4791741e:m:mTOEokGjjrI1HKVObBD73mA
Post by: fekbmax on September 14, 2017, 05:47:21 AM
Its a good tool and works well. Tim makes a few great products for the FE.
Post by: scott foxwell on September 14, 2017, 07:30:03 AM
It wouldn't be hard to adapt something like this; this is a ProForm el-cheapo but the one from LSM (best one made IMO) is almost identical.
(https://sep.yimg.com/ay/chucker54/proform-cylinder-head-mounted-valve-spring-tester-24.gif)
Post by: jimeast on September 14, 2017, 10:36:38 AM
Neither of these have gauges that go to 700lbs
Post by: scott foxwell on September 14, 2017, 11:21:11 AM
You're checking seat pressure, not open. You don't need 700#.
Post by: jimeast on September 14, 2017, 11:34:17 AM
Thanks, I would have assumed you would check pressure throughout the range.
