FE Power Forums => Member Projects => Topic started by: edgarval on August 09, 2017, 12:17:06 PM
Title: My first fe build
Post by: edgarval on August 09, 2017, 12:17:06 PM
Excited picked up a 390 crank and rods . Going to machine shop here in Houston . STD fe block . Was originally had a 360 crank . Tossed that out .
Title: Re: My first fe build
Post by: tomsfe64 on August 10, 2017, 12:32:52 PM
Has the crank been turned .030 already? If you cut it more it might be less than optimal.
Post by: edgarval on August 11, 2017, 09:41:50 AM
I have not taking it in yet . It says standard hoping it will only need just the minimum.
Post by: hwoods on August 11, 2017, 11:41:30 AM
I am in the Houston area, what machine shop are you using?  My block is at Nickens Bros in Conroe TX
Post by: edgarval on August 12, 2017, 12:58:29 AM
I'm going to take it to h.e.b . I hear he has some fe cars also.
Post by: Bolted to Floor on August 13, 2017, 12:16:19 PM
Jeff at Houston Engine and Balance is a good guy that knows the FE's. He did all my machine work and break in on the dyno.
I always ask for ball park pricing on any type of work with whoever I deal with. Jeff came in less than stated on both occasions.
Post by: edgarval on August 14, 2017, 02:56:10 PM
Yes price quote he gave me was good . I can not wait to take it in .
Post by: edgarval on November 17, 2018, 08:17:05 PM
2-d3te mirror blocks
