FE Power Forums => FE Technical Forum => Topic started by: fryedaddy on June 05, 2017, 12:10:48 PM
i switched from cj heads to bbm,before it liked 41-42 degree of total timing with my msd pro billet dist.i knew the bbms required less timing.my engine still seems to like 39-40.does that sound ok or too much.need some opinions.
How do you know it likes it?
from test driving,,hell i dont know,what is normal,i dont have any fancy dynos or expensive gadgets.just the seat of my pants.i have a 25 degree bushing now with 14 int and 39 total.does that sound reasonable,if not any sugestions
I have another question to add... Is it a matter of too much total time or total time is too early? In other words, perhaps a slower rate of advance is needed?
I ask not so much to help fryedaddy but rather I'm hoping for any advice to help my understanding. The dizzy on my pickup is set up to hit its max advance around 2700 crank rpms. The dyno showed no more peak power was made above 32 total time. I've been running 12 initial but seems like other BBM head owners are liking 18-20 initial. I'd wondering about bumping up my initial but slowing the rate of advance so that I don't hit total time of 32 until a little higher rpm.
My dizzy already has the heavy springs installed so I can't slow the advance rate anymore. If I set initial to 18 then I'll be at 32 total time by around 2000 crank rpms. Seems early to me.
Ii have 1 lite spring and 1 med spring all in by 25-2700.do you have a 390 or 428,the 390s dont need as much timing as the 428.my engine is running fine,i just want to be safe with my timing settings.i have a spring-bushing kit,i can change them out if i knew which ones would work best for me
.im just your average joe who happens to love and run fe engines for over 40 years with no special tools or skills
want do some of you 428 guys normally set your timing on with bbm heads,initial and total please.
how about a reply or two,i have my dist out today,it would be a good time for a bushing-spring change if i need to.right now it has 25 bushing and 1 lite spring and i med spring
i have my distributor right here on the table laid out with my bushings and springs msd8495 wondering which ones to put in
I've never run or even seen BBM heads, but if they have an efficient chamber that doesn't need a lot of total advance, you want a very fast advance curve. So if you only need 34 degrees total advance, I'd use the one of the quickest bushing/spring combinations with the MSD distributor. I think the black bushing has 18 degrees of advance. I'd use that. Set your initial timing based on your total. So you if you need 34 total, set the the initial at 16. Depending on your combination you can choose springs to bring in the total when you want it. I'm guessing you want it pretty quick, say in the 2500-3000 rpm range.
JMO,
Black bushing, set total at 32 degrees and try it.
I run two light blue springs. Should be all in by 2500-2600.
i just put the blue one in its 21 degree adv.on a 428 are you sure 32 total is enough.i can take it back out and put the 18 in but i would have to set int timing on 14,is that ok.if im guessing right its not as much the bore and stroke as it is the heads when figuring timing.i going back out to the garage and taking the dist back out.i will put the black bushing in,lite blue springs.it will be 14 int 32 total,if i have to add a couple int,it will still just be 34 total.where is the save zone31-38?i just dont want to mess up a new engine by having the timing off bad
32-34 degrees total is where you need to be.
I'd use the black bushing....
You don't have to pull the distributor out, you can hot swap the guts with the distributor in the engine.
just got back in the house after running my engine for a bit.im going the right direction.with the 21 bushing in 14 int and 35 total and the lite springs in,it sounded way crisper when revving.im going to drive it and see how it does before i try the 18 black bushing.BRENT i replied before i read you post.i will put the black one in and make sure its not over 34 when i try it
Give it a shot and try it. Remember, if the seat of the pants doesn't change (or dyno, or ET) with the total timing pulled back, then it's a win/win situation.
In a lot of engines that I dyno with BBM heads, the power doesn't change from 32-36 degrees total, but you're always better off with some more toleration to pump gas.
A quick curve won't show up on the dyno, but it will in the car...
Good chamber, tight quench, high compression, rich mixture, all lower the requirement for total timing (while allowing it to be more tolerant of a quick curve)
Open chamber, loose quench, low compression, lean mixture, all raise the amount of total timing (although many of those things make it unhappy to get what it wants)
I haven't done any BBM stuff, but sure see the guys who do make power closer to 32, I wouldn't sweat it. Then you can have it come in quick as Brent said for part throttle snap on the street.
All makes perfect sense
This is most definitely a tangent, BUT one thing I (almost) never see mentioned with regard to timing, is octane and compression ratio. I think octane and the resultant time of ignition affect the timing requirement, especially in combination with compression ratio.
I don't have a tome of empirical evidence to back it up. I can remember one event which drove this home to me. I had a low compression 428 (9.3:1) with a decent sized cam in it 242/246, on the dyno. We used race gas just to be safe since it was a brand new build. I don't remember the exact octane, but it was race gas. It was certainly over 104 octane.
So........this engine kept making more power as we increased the total timing. We got up to 45 degrees total and it was still making more power. I got a little freaked out at 45 degrees total and stopped adding timing, despite the improving power figures. It just seemed weird. TDC and the balancer had been checked afterwards to verify the numbers. I'm using all the same pertinent parts including the distributor on my current 428 build and it likes a "normal" 37-38 degrees for an Edelbrock chamber.
I don't think the rate of combustion is significantly affected by octane and compression, but I do the think the time of ignition is affected.
Like I said, it's just a tangent for 99% of applications.
JMO,
edit: Hmm. I say that and then it doesn't make sense. Certainly most people would think that the "time" of ignition is rigidly controlled by when the spark is ignited. I'm not so sure that I'm right now that I think about it a bit more. I'm not sure that I'm wrong, either though. It may be much more complicated than we think. The combustion process is probably not linear in terms of it's speed. I know this all sounds esoteric, but I don't think it is.
Best way is MPH or timed pulls from some MPH to some MPH. I can tell you that with the AFD heads in the dragster, a drift from 28 degrees to 34 kills a little over 4 MPH. Thats at 11.8:1 with leaded 110 racing fuel.
Its really easy to google "gas octane test" and find old poprod ore hotrod magazine tests when you still could get 100 octane gas. and see what octane does to advance timing needed. NASCAR engine 101 on you tube is very informative on the subject also.
Higher octane gas like 100+ in a engine with 9:1 something static comp is a waste of power/time consuming combustion
higher octane burns slower, to gain near the same power with 104 octan as with say 98 0ctane for an engine like dis you have to advance the timing like to maby45¤ advance.
Every Engine has its on ideal crank angel maximum combustion pressure / degree depended on stroke / rod ratio etc. that's the spot we are looking fore to hit.
As mentioned here before me, a richer fuel/ai mixture ( more / closer to each other fuel particles will burn faster and vice vers with a leaner mix,
and to that dynamic combustion pressure difference/ throttle openings rpm/ overlap hot gases situations
Assuming (You don't win races assuming) all is god with ignition system and plugs intake carb and so on. (Will try to get dis understandably )
AT WOT and just WOT the engine wants less advance at peak torque ( cylinder max packed with fuelmix faster burn ) than peak power and should have a slop on approx 1¤ advance/1000 rpm or so depended up on engine type up to peak rpm ( less VE ) fore max power.
In Dyno test you almost never read more than " it made max power at that advance " then it coms in to play the vehicle it self
light,heavy auto/ manual gearing converter gforces on intake tract and carb ( go in to youtube BLP N&S test jmarkaudio) something and look watt happens to fuel in carb bowl up on dragrace launches and figure if that's altering you jetting / E bleed calibration compared to dyno pulls )
Bill Jenkins was the first ( I belief ) to have a high gear retard in his 327 S/S chevy II manuel trans. The trick was to have a 42-44 advance ( as i recall ) launching the car to make it rev faster and then retard to 38( ore watt ever it was) in higher gears when the engine was loaded and working hard fore best power. Combustion it self takes the same amount of time provided the same fuel air mix and so on , piston speed goes up in square by rpm ( i think it was, my old beat up brain cant remember as much as i want to ) Any way the important ting to remember is like Blykins seas
GO FORE LEAST ADVANCE TIMING TO MAX POWER not max advance to max power A light car low gear high stall conv. can take a faster advance curve than the opposite combo. Then we have the cruising advance situation all ready mention several times last week come in to play
Phuu :P
Heh.... this is diesel engineering 101 in regards to fuel burn.
Yes, in gasoline engines people don't think much of it due to burn rate, but in large industrial diesels this is a well known principle. Always consider your fuel and it's characteristics. There is timing (we know this one), injection lag (how long it takes for the full fuel load to be delivered with the injector stroke), ignition lag (how long it takes for the fuel to begin igniting, and how long it takes to fully burn), atomization vs penetration, all are important considerations, etc. The larger fuel particles penetrate further into the chamber, while the finer ones burn rapidly, often so rapidly that unused oxygen is still available..... (the redneck pickup truck crowd blowing black smokes comes to mind).
These are all factors that are very important in a diesel, especially when you are dealing with a bore and stroke larger than ten inches.
Gasoline engines are no different in that different grades of fuel burn faster or slower. To throw in another curve ball with a gasoline engine you have rich and lean burn characteristics that very greatly with everything else being exactly the same.
With my specialty (2stroke diesels) this is even more critical as you have considerably less time to burn the fuel properly before the engine is pumping fresh air into the cylinder.
i failed to mention that i run half 110 leaded and half 90 no ethanol and im around 11 to 1 compression,could that be why i thought i needed more timing
Technically, you would need less with higher compression and an efficient chamber.
I would run a little colder plug too.
thank you everyone.it think im about to get this straightened out.i put the black bushing in ,lite springs.that let me set my initial to 16 which let me back my idle screw on my carb off alot. win win thanks
Hey Fryedaddy , i am running the black bushing , and 14 initial with my BBM s , it s on a 428 .. Bud
thank you,all i wanted to know was those settings.im going to keep it in the 32-34 range from now on.i have it on 34 right now and its running like a scalded cat,im happy
Good to hear wish i could tag along for a ride with you. :) :)
So here's what I'm wondering. Does an engine run best on the lowest octane fuel that is sufficient for its needs? Maybe less total timing needed? I'm not saying that's a good thing to do in practice, as you want some cushion for different driving conditions. Still, as a theoretical question?
As a theoretical question! Yes if one look at it octane only wise. Different fuel labels can have different additives that of cause com in tho play also Earlier start of ignition point, fight against piston upwards motion fore a longer time, and in general lower octane burns faster / needs less advance = more power I keep telling you good folks GO IN TO "NASCAR ENGINE 101 ON YOU TUBE and give it 40 minutes very informative on the combustion subject and Why they have " splited" different timing points to all the cylinders.
I do not have enough time to get too deep into this discussion - but need to point out a couple things.
Fuel burn rate and octane are two different characteristics of race (or street) gasoline. Octane is the resistance to self ignition and does not tie directly into the rate of burn once that ignition occurs. They are obviously inter-related as all chemistries are- but race gas does not burn slower than pump gas as any sort of rule.
Think about it for a moment. Both fuels are designed and optimized for a particular need. A street engine will need to run its best at idle and lower RPM. A high performance application will need to run its best at very high RPM. At high RPM you have much less time available to use for each combustion event. In order to get the combustion event completed and get the most power from the engine you will want the race gas to burn faster...and it does....
I think this is the video you are referring to?
https://www.youtube.com/watch?v=rBZCnG1HwDM
It's pretty informative. Thanks for that.
I notice when talking about combustion speed, the measure is usually pressure vs. time. I think it would be interesting to see mass vs. time. That is, the mass reacted vs time. I'm not exactly sure where I'm going with that. It just seems like it would be helpful to understand the combustion process. Measuring pressure is an indirect means, and influenced by other variables, I think.
JMO,
I was confusing, maybe contradicting myself, with time of combustion and rate of combustion.
One might think that combustion starts with the spark and that is that. Then you have the rate of combustion, and that is that. I'm thinking there's a lot more to it which I'm sure you know.
I'm guessing the octane affects the early combustion rate. So after the spark, the octane affects the early part of the curve? This in turn affects the required timing, which makes us think the combustion is starting later, but it really isn't. It's just the early part of the process is slower? So you have to start it earlier to get to the same peak pressure at the same time?
Not to confuse the issue, but I think compression ratio affects this, too. Higher compression imparts more energy to the air and fuel molecules which makes them easier to ignite. It also moves the molecules closer together for more and more frequent collisions, increasing the speed of combustion. I imagine this is obvious for the professional engine builders, but I'm still thinking it through. :o
Thanks for pointing that out. Another testimony to stable fuel is a hot soaked carb. Although my truck will run 87 octane and only sacrifice .5 mpg it does boil the fuel and flood. It takes about 30 minutes sitting off with the current 1" aluminium adapter. No problems running 93 octain or stacked with a phenolic spacer under the adapter.
i dont know if any of this would come into play,but my comet weighs 2950 with me in it ,high stall auto ,low geared rear
As long as we're all here talking about timing...
I set the timing in my truck by putting it at 32 degrees at 3000 rpm or whatever rpm it stops advancing. The initial timing ends up at 14 or so depending on how fast the idle is. BUT THEN I hook up the vacuum and it will advance even more than my 32 degrees when over 3000 rpm. How much farther is hard to tell, am I doing this right?
That sounds right, its not unusual to have advance up to 45 or even 50 degrees when the engine has vacuum. The engine can use a lot of advance in a high vacuum cruise situation. Sounds like you are doing everything right to me...
Paulie, if you ever get interested in studying fuel movement, timing effects, etc this is a great search engine of papers that were written when this was THE cutting edge field.
https://ntrs.nasa.gov/search.jsp?N=17
Thanks Drew! I will check it out when I get a chance. Probably 3 am. ;D
