FE Power Forums => FE Technical Forum => Topic started by: Heo on June 01, 2017, 05:48:32 PM
I removed the frontclip from the Galaxie to paint the
firewall and frontend of frame when the engine is out
But there is no way to do it with any satisfying result
without tearing down the frontsuspension so i just
degreasing it for now and tear it down this winter..
So where can i buy suspension bushings preferably
better than stock,Springs,shocks,swaybar?
Heo, I used rareparts.com for my '63 Galaxie. Bruce
These folks are good too... https://p-s-t.com/ I've had my car so long,I'm on the third set of control arm bushings. :)
Dearborn classics has a bunch of nice parts available, 90 percent are stock replacements but they have some upgraded parts as well, and through my experience all the parts are high quality and fit better then the rest I have tried, bar none.
you might try Mac's
Thank you guys Mac and Dearborn is the same Eccler company today
ordered fenderbadges from Macs got them from Dearborn or the other way around
Read some bad stuff about Eccler but no problem for me so far
May as well toss in Dennis Carpenter as a potential source also. Just got some parts for my F100 form NPD and they were in Dennis Carpenter bags. I got burned by Macs once so I don't buy there any more. Might be best to shop price for the kit you need from one of the bigger suppliers due to your location.
I got my '64 front end suspension parts through a place called "ESPO Springs 'n things" right here in Pennsylvania. Everything was spot on.
Found quickor garage. They have front and rear swaybar
Moog still makes lower A-arm bushings "MOOG K200963 Front Lower Rearward $15.31 at Rockauto.
Mood also has ball joints, front coil springs.
