FE Power Forums => FE Technical Forum => Topic started by: Katz427 on May 20, 2017, 07:45:59 PM
Has anyone used the Black Eagle racing motor mounts for Fe in a fairlane or comet that are on eBay?
Yup. Welded up the first set made.
Jamie, question on height. Are they same as stock mount height?
Yes. Motor sits where it should from factory. The guy that sells them is a dink though. Way over priced.
Also on edit they are harsh on the vibration .
Well that is pretty good then. May be a bit pricey but near everything is. I do not have a shop handy these days so I do what I can. I would like to install my 427 in the 67 Ranchero. It is a 5.0 right now. As you know room is at a premium under hood. I might do a little work on the shock towers but those mounts free up a little room around the cross member.
If i had more time id send you a set free.99. Still have the program to laser them out.
