FE Power Forums => FE Technical Forum => Topic started by: plovett on April 24, 2017, 06:01:19 AM
Title: Shortest deck height on a factory block FE?
Post by: plovett on April 24, 2017, 06:01:19 AM
What's the shortest deck height anyone has run with no issues on a factory block FE?
I understand intake manifold fitment has to be dealt with.  I'm more curious about the structural integrity of the block, retaining head gaskets, etc.
I think 10.15" is not uncommon at all.
So the question is, how low can you go?
thanks,
Title: Re: Shortest deck height on a factory block FE?
Post by: blykins on April 24, 2017, 06:34:58 AM
I have went 10.135" a couple of times.
Post by: XR7 on April 24, 2017, 10:23:44 AM
Hi Paulie, on my old beat up center oiler, it must be about 10.132 as the pistons (normal stroker deal) that I ordered for a zero deck at 10.150 are .018 out of the hole! I used a Cometic 5 layer head gasket at .060 thick and all is well, no issues at all. I have re-used those gasket twice now and will re-use them again when I put my high riser heads on soon. Those gaskets are expensive... but I had no other choice.
Post by: 57 lima bean on April 24, 2017, 11:16:27 AM
"I have re-used those gasket twice now and will re-use them again when I put my high riser heads on soon"...anything special to know when cleaning these gaskets?
Post by: gt350hr on April 24, 2017, 11:34:16 AM
   10.130 is the shortest I have seen.
Post by: plovett on April 24, 2017, 05:13:19 PM
Thanks guys!
That gives me a ball park figure, and a sanity check.  My next combo will require custom pistons in any case, so I was just wondering how much I could reasonably move things around.
Post by: edgarval on May 17, 2017, 09:00:12 PM
Is 10.3 even shorter ?
Post by: gt350hr on May 18, 2017, 09:30:39 AM
    No 10.3 is taller and the same as the 429-460 , 351M-400.
