FE Power Forums => FE Technical Forum => Topic started by: Cobravii on February 14, 2017, 09:20:46 PM
Title: pulleys don't line up?!?!
Post by: Cobravii on February 14, 2017, 09:20:46 PM
Has anyone seen this before?
It is a scat crank, I have new timing gears, no oil singer, new spacer and new balancer but when I install everything my pulley are one groove out.
Title: Re: pulleys don't line up?!?!
Post by: rhinosoft on February 14, 2017, 09:59:19 PM
I have a very similar setup with new SCAT stroker and balancer also. The water pump I have is cast iron and I cannot recall the pulley being so close to it.
When I get home I can send images of mine, everything seems to line up - would that help?
Graeme
Post by: Cobravii on February 14, 2017, 10:19:29 PM
my water pump is aluminium. could it need a spacer?
Post by: rhinosoft on February 14, 2017, 10:27:38 PM
Don't know, just pointed that out. Wait for the guys to login later and you will find out.
Graeme
Post by: rhinosoft on February 14, 2017, 10:43:31 PM
Can you post the brand of your new balancer as well?
Post by: rhinosoft on February 15, 2017, 04:08:37 AM
Here are some images - might help a bit, not sure, image of the part number for the new balancer as well. Everything seems to line up nicely with this setup.
Graeme
(http://i662.photobucket.com/albums/uu349/rhinsoft007/IMG_20170215_181220_zps5oosdya0.jpg) (http://s662.photobucket.com/user/rhinsoft007/media/IMG_20170215_181220_zps5oosdya0.jpg.html)
(http://i662.photobucket.com/albums/uu349/rhinsoft007/IMG_20170215_181307_zps3lebuhu7.jpg) (http://s662.photobucket.com/user/rhinsoft007/media/IMG_20170215_181307_zps3lebuhu7.jpg.html)
(http://i662.photobucket.com/albums/uu349/rhinsoft007/IMG_20170215_181332_zps6aic7srm.jpg) (http://s662.photobucket.com/user/rhinsoft007/media/IMG_20170215_181332_zps6aic7srm.jpg.html)
(http://i662.photobucket.com/albums/uu349/rhinsoft007/IMG_20170215_181430_zpsyqc4h7db.jpg) (http://s662.photobucket.com/user/rhinsoft007/media/IMG_20170215_181430_zpsyqc4h7db.jpg.html)
Post by: My427stang on February 15, 2017, 04:29:52 AM
I am not sure how that could happen unless you have some wrong parts.  A small misalignment could happen from the crank, but not over 1/2 inch
Post by: jayb on February 15, 2017, 07:49:52 AM
I was going to say the same thing.  Did you get the pulleys in a set, or separately?
Post by: Cobravii on February 15, 2017, 11:07:37 AM
This is my spacer: http://www.ebay.ca/itm/252708855175?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
This is the balancer: http://www.ebay.ca/itm/182291045773?_trksid=p2057872.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
The pulleys were purchased as a set
Post by: Drew Pojedinec on February 15, 2017, 12:44:27 PM
When you installed the crank spacer, did it push all the way back?
When you installed the balancer, how close did the end of the crank come to the end of the balancer?
Post by: Cobravii on February 15, 2017, 07:45:18 PM
I'm going to flip it over and pull the oil pan so I can see down inside the timing cover.....
Post by: Drew Pojedinec on February 15, 2017, 08:15:37 PM
Dunno if it's a common issue or what, but I had to sand the crankshaft keys to fit both the crankshaft and spacer.  It wanted to bind otherwise.
Post by: Cobravii on February 16, 2017, 09:06:21 PM
Ok, so today I pulled the pan and could no see any gaps BUT I think I may have pulled a rookie move. Is it possible to install the lower crank gear backwards? If it is, I think I found my problem.
Post by: jayb on February 16, 2017, 09:20:59 PM
If the crank gear is on backwards the timing chain would be seriously misaligned.  If it is, then what you said would make sense, because the crank gear has a relief in the backside to allow it to slide further onto the crank...
Post by: Cobravii on February 16, 2017, 09:52:31 PM
nope, timing chain is straight as an arrow and the timing marks are on the outside. Weird.
I'm going to tear down the from end next days off.
Post by: Cobravii on February 16, 2017, 10:24:16 PM
the spacer is same length as the stock. my next suspicion is the balancer.
Post by: Drew Pojedinec on February 16, 2017, 11:05:47 PM
With the crank bolt out, how far is the end of the crank to the end of the balancer?
The crank *should* be just a tiny bit deeper.
Post by: Cobravii on February 17, 2017, 10:52:00 PM
it was about 3/4 inside the lip of the balancer
Post by: blykins on February 18, 2017, 08:46:43 AM
Then something isn't seated.
The crank should *almost* be flush with the balancer.
Post by: Drew Pojedinec on February 18, 2017, 02:28:15 PM
That is why I asked..... it should be 1/8 of an inch before tightening the crank bolt, and 1/16 or "dang near flush" after tightening.
I think one of the keyways is holding your crank spacer from seating all the way in.
If this isn't the case than it has to be the timing gear not fully seated (This is why I asked how close they were 3 days ago).  When I was building my engine, it sure seemed like it could be an issue if you don't custom fit the keys.
Post by: Cobravii on February 25, 2017, 07:52:20 PM
Ok, I took off the timing cover and checked the bottom timing gear and it only has timing marks on one side so that theory is out. I did dress the keys so the spacer and pulley fit on better.
When I slide the spacer on I have 1" of crankshaft left to fit the balancer on and when I put the balancer on the crank is approx 3/4 inch from the edge of the balancer.
I am at a loss. The spacer was new and is the exact same length as factory. I don't have a factory balancer to compare to. mynonly two guesses are the bottom gear is shaped wrong or the balancer is wrong.
Post by: KMcCullah on February 25, 2017, 08:23:50 PM
I'm thinking the harmonic balancer since it's a race style. Some of the additional width of the outer ring is on the pulley side I'd bet. So the mounting face for the pulley had to move forward too. Maybe. Lots of aftermarket stuff combined together has messed with me before.
Post by: blykins on February 25, 2017, 09:24:21 PM
Not the balancer.  I use a ton of that same one and haven't ran into anything like that.
You should have around 3/4" of crank showing after the spacer is on.  When you install the balancer, it should stick out past the crank just slightly.
Post by: jayb on February 25, 2017, 10:10:06 PM
Judging by the photos the crank sleeve is on all the way.  In that case, the only explanation is the balancer isn't pushed on all the way, or the balancer is too thick.  The balancer will often press onto the crank kind of hard.  Did you have to pull the balancer off with a puller, or did it come right off?  Is it pressing completely onto the crank?
Post by: Cobravii on February 26, 2017, 02:06:18 PM
the crank gear, the spacer and the balancer are on all the way. before I put the balancer on there is approx an 1" of space left on the crank. I'm thinking the balancer is twice as thick as factory. If it is I think my solution is to shorten the spacer.
Post by: blykins on February 26, 2017, 02:14:52 PM
How thick is your balancer?
As I mentioned earlier, I use those same balancers on almost every street engine I build.  I have never had any pulley alignment issues.
Post by: Cobravii on February 26, 2017, 02:50:18 PM
The hub is 1.5" thick
Post by: My427stang on February 26, 2017, 03:34:50 PM
Just want be very clear in a question, did you measure the balancer bore depth (or thickness) (I think that is your 1.50 measurement) and does someone have a stock Ford balancer to do the same?
Sorta looks like the balancer is thicker in the center, I have never seen one hang over 1/2 inch like that
Also, is the amount "left over" the same dimension as the pulleys are off?
Last question, do the timing marks like up at TDC?  Just wondering if this is the wrong balancer altogether
Post by: Cobravii on February 26, 2017, 06:03:07 PM
All excellent questions....
The part I measured was the hub thickness, I don't know how thick a stock balancer is and the "leftover amount looks to be exactly how much my pulleys are out of alignment.
TDC does line up correctly.
I'm willing to bet the hub on my balancer is twice as thick as it is supposed to be. If it is I'm still thinking the easiest fix is to mill off the extra amount from the balancer end of the spacer.
I also sent an e-nmail to my supplier to see if he has seen this before or if I was supposed to make alterations but didn't know to do it.
Post by: Cobravii on February 28, 2017, 04:13:25 PM
Ok, so it is confirmed. It is thee balancer that is too thick.
The supplier is taking it back and hopefully he can get me the proper one. If he can't I am in the market for a good quality balancer. Does not need to be SFI
Thanks for all the input everyone.
Post by: ericwevans on February 28, 2017, 07:08:10 PM
I am running this one on my 352 with no issues.  Timing marks are etched and very clear.
https://www.summitracing.com/parts/pfs-90009/overview/make/ford
Post by: Cobravii on February 28, 2017, 10:29:17 PM
I've heard good reviews on that balancer.
Post by: Cobravii on March 31, 2017, 11:17:54 PM
Great news! I finally received the correct balancer. The first two sent to me were both wrong applications. The first was for a 429 and then second I think was a for  chev.
Post by: ericwevans on April 01, 2017, 12:15:34 AM
What are you putting that in?  Specifically looking at the headers.  Planning on doing fenderwell headers on my truck, but they have to come horizontal of the heads not straight, otherwise I would think that is your plan.  They look sweet.
