FE Power Forums => FE Technical Forum => Topic started by: Old Blue 67 on November 25, 2016, 04:54:35 PM
I know I should use the kits that our vendors here recommend, but I have a close friend who owns a local speed shop here in town. He can get me an Eagle 462 kit at his price which is VERY good. How do you guys like the Eagle kits. The intended use is a hot street cruiser 462 in a 67 F100.
I've seen MULTIPLE Eagle FE crankshaft failures across the various forums....
I would pass....
Not an Eagle fan, either. The Scat is better for sure. Sometimes, you get what you pay for.
what about the RPM Forged steel stroker crank?
Thanks for the replies guys. I'll check to see if he is a Scat dealer.
The only issue that I have with the RPM cranks is that they are all oversized in journal diameters. The cranks themselves are nice but you can count on having to have them touch-ground or cut .010/.010 before you even get started.
I do almost exclusively Scat for the reasons mentioned.
I have only see three broken stroker FE cranks and two of them were Eagles in a very mild application.
Brent , Blair , and Barry build every day and have tested so many different parts , listen to them and your build build will be reliable for sure ..Bud
Following this thread with interest. I haven't heard of issues with broken Eagle cranks, but have been warned to run away from hyper-eutectic pistons (which I think is part of the Eagle kit) due to their tendency to shatter, and that forged pistons are cheap insurance (the Scat kits include forged pistons). Any opinions on kit pistons?
