FE Power Forums => FE Technical Forum => Topic started by: Qikbbstang on September 29, 2016, 03:33:01 PM
Title: Using factory FoMoCo 390GT/428CJ dipstick tube and dipstick w/headers what's
Post by: Qikbbstang on September 29, 2016, 03:33:01 PM
"cleanest" looking means to bolt/secure the dipstick tube to where it usually resides w/o ex-manifolds in place and of course w/headers?
Just jerry-rig it to header flange?
Title: Re: Using factory FoMoCo 390GT/428CJ dipstick tube and dipstick w/headers what's
Post by: Drew Pojedinec on September 29, 2016, 05:48:02 PM
I just buy 3/8 Fuel line, make what I need, weld a sheet metal tab to it.
Grind/clean it up and paint it.
Post by: Qikbbstang on September 29, 2016, 11:47:09 PM
Drew the little things FE I really like to keep original FE--- the use of a factory chromed dip-stick is mandatory and the FoMoCo dip stick tube itself is near as mandatory to me... I have one original dip-stick tube that shows to be actually plated with copper or something.
 I don't mind swapping factory pent roof VCs for the chromed 390GT/428CJ Powered by Ford VCs ... but the chromed dipsticks were actually unique parts of the 390GT/428CJ's
Post by: Drew Pojedinec on September 30, 2016, 09:13:27 AM
Cool, so just put the manifolds back in place and you won't have any issues :P
Or buy a tubing bender and try to move your dipstick to where it needs to go
Post by: thatdarncat on September 30, 2016, 12:29:15 PM
What I did on my '67 Shelby that you saw on Drag Week last year is use a piece of 3/4" x 1/8" flat aluminum like you find at the hardware store. I bent it at a 90 degree angle and drilled a hole at the front to bolt to the lower hole on the front of the FE head. On the side I drilled and tapped a 1/4" hole and bolt the stock dipstick tube tab to that using a short 1/4" bolt. It's hard to see on the picture, but that bolt ends just past the aluminum strap. No nut is needed on the back side because the aluminum piece is threaded. This works for me since I only use the top & bottom bolts on the header and not the side by side bolts, so there is no header bolt there to interfere. If you wanted to put a header bolt in that front exhaust bolt hole I think the easiest solution would be to just use a stud there - put a nut on first to tighten the header - then another nut over the dipstick tube tab. Another option would be to just use the 427 dipstick tube that has the longer mount tab that goes to the front of the head and you could still use your chrome dipstick. Here's a picture of mine:
(http://i1235.photobucket.com/albums/ff437/red0wl/Dipstick%20mount%20rs.jpg) (http://s1235.photobucket.com/user/red0wl/media/Dipstick%20mount%20rs.jpg.html)
