FE Power Forums => FE Technical Forum => Topic started by: Wreckless Warren on April 24, 2012, 03:06:27 PM
I have a real nice Rotunda 8K tach & NOS cup that I want to have restored and use it on the P-Code restoration. But I also am thinking about running an MSD Pro Billet Dist and either a 6AL-2 or Digital 6 Ignition Amplifier. Has anyone made this combo work? I assume you would need to use the MSD "Tach Adaptor" if it did.
How about using one of these classic tachs with a Pertronix Ignitor or Ignitor II? Anyone have this setup working?
For those using a Rotunda/Faria tach, what ignition system are you using?
As always your input is appreciated. ww
you should be able to hook your tach right to the MSD unit's tach connector , it suposed to pulse like a normal ignition for tach feed
