FE Power Forums => FE Technical Forum => Topic started by: fryedaddy on July 10, 2016, 01:41:25 PM
Title: header leak or engine noise?
Post by: fryedaddy on July 10, 2016, 01:41:25 PM
i have a pecking or header leak i cant figure out.i have new header gaskets and i have a noise on the driver side.i pulled no. 7 plug wire and it almost stopped.it quietened down alot,could i have a crack in no 7 tube,headers are old and have cracked before or would it be a lifter or worn lobe on no 7?why did it get quiet when i pulled no 7 wire?
Title: Re: header leak or engine noise?
Post by: cammerfe on July 10, 2016, 02:03:13 PM
If the noise is purely mechanical---such as a lifter---the cylinder firing would make almost no difference. What you've described makes me lean toward a leak (crack?) in the header. if you 'crack' it in the dark you may be able to see something.
Post by: fryedaddy on July 10, 2016, 02:24:47 PM
its pretty loud ,you can hear it over the exhaust,but when i pull the wire it gets so quiet you can barely hear it.put the wire back on and it gets loud again.i was worried about the lobes on the no 7 cyl. anyway because my cam is used and the engine i took it out of busted a sleeve in the no 7 cyl. i dont know if that would affect the cam or not by busting that cyl? a screw dropped down the carb and ended up in the no 7 cylinder of the other engine and ended up busting the cyl wall and beating up the piston,could that have hurt the cam and be causing the noise?i hope its a cracked header,im wanting some new ones anyway.how can i tell,im just a shade tree with few tools.
Post by: cjshaker on July 10, 2016, 03:00:52 PM
Like Ken said, it doesn't sound mechanical, and if you run it when it's really dark, goose the throttle, you may be able to see some flashing or flickers of light indicating escaping exhaust/flames from the combustion. Or if the engine is cold, start it and feel around the tube to see if you can feel any pulses of escaping air. You have to be pretty quick on that one though because the tube will heat up quick. If everything is clean enough, another way would be to look very closely for any dark sooty areas indicating escaping exhaust. You might have to crawl underneath to see the underside. If they've cracked before, chances are it's cracked again, or you've just got a bad gasket.
Post by: Jim Comet on July 10, 2016, 03:03:50 PM
I was helping a friend on his small block Falcon the other weekend an we had a ticking that we all swore was coming from the drivers side valve train. Pulled the cover and could not find anything wrong. Noticed a poor fit on the spark plug boot when we reassembled it and the noise was still there when we started it. We decided to address the spark plug boot fitment and when fixed the noise was gone. It was spark arcing to the header. Jim
Post by: fryedaddy on July 10, 2016, 03:12:04 PM
thanks guys,i really hope you are right about it being the headers.i will check the best i can for a leak tonight when it gets dark.i would love to put a new set of headers on and it cure the problem.thanks again.i hope its not the valve train on this new 433 fe
Post by: shady on July 10, 2016, 04:54:54 PM
a cracked piston skirt will stop knocking when a plug wire is pulled. usually worse when cold.
Post by: fryedaddy on July 10, 2016, 05:54:01 PM
i hope it aint a cracked piston skirt,i have a new set of speed pro forged alu. pistons in a fresh .30 over 428 block with less than 1000 miles on the engine.i think it gets worse when hot
Post by: fryedaddy on July 10, 2016, 06:28:52 PM
if you rev it up a little its less noticeable but still there
Post by: Heo on July 10, 2016, 07:03:25 PM
Dont think its valvetrain when it changes when you pull
the plug wire. Header leak,Bad bearing,bad piston pin bushing
cracked piston. To much  piston clerance in no 7
Post by: fryedaddy on July 10, 2016, 07:28:53 PM
after hearing all that,i sure hope its a problem with the exhaust
Post by: fryedaddy on July 15, 2016, 03:46:33 PM
i drained the oil and pulled the filter and cut it open,not a spec of medal nowhere in the oil pan or filter.i guess that tells maybe no spun bearing.if a compression test goes well too,maybe it could be a exhaust leak.
Post by: C6AE on July 15, 2016, 05:08:28 PM
Sometimes you can pinpoint a leaking exhaust joint by using a short length of heater hose as a stethoscope. Hold one end to your ear, move the other end basically from port to port. If it is an exhaust leak you can usually find it right away. (Sometimes the exhaust cross-over can leak, I found a manifold once with a pin hole burned clear through near the base of the carburetor)
Post by: fryedaddy on July 16, 2016, 01:21:54 PM
thank you,i have patched,scabbed,ground,and bent these old headers one time too many.time for a new set even if the problem turns out to be something else.
Post by: Lenz on July 16, 2016, 04:28:35 PM
I'm on board with a likely exhaust leak.  Experience has taught me that a leak can sound just like metal hammering metal.  Before you get any further you sure want to eliminate that end of it, everything else costs a lot more and might send you digging way deeper than you may need to.
Post by: fryedaddy on July 23, 2016, 08:10:49 PM
UPDATE.i took my driverside header all the way off my comet today.the cylinder in question,no 7.i wouldnt sure if it was a header leak or engine noise,i know now.there is a hole about the size of a pinto bean about 6 inches from where the header meets the head.im going to try to weld a patch over it for now,if i dont blow a bigger hole in it trying to fix it.there pretty thin,being 36 years old.i guess i will order a new set if the patch dont hold.
Post by: ScotiaFE on July 23, 2016, 08:17:12 PM
Only got 36 years out of them.
Damn, you must be looking for a pro rate refund on that. ::)
Post by: fryedaddy on July 23, 2016, 10:17:58 PM
i gave 215 dollars in 1982 for them.at the time a set of sbc headers was on the sign outside for 59 dollars.the guy behind the counter felt so bad about the price,he knocked off the taxes. i guess thats only 34 years not 36,their practically new
Post by: fryedaddy on July 25, 2016, 12:31:56 PM
i put a patch over the hole in my header today.it turned out ok.i found out why i had a hole ,my engine mounts have a sharp edged corner sticking out,and when i backed out of my driveway too fast i drug my headers backwards into the corner of that engine mount.ended up with a hole there
Post by: shady on July 25, 2016, 01:04:06 PM
glad it turned out ok. 1n 1980 I bought a set of black jacks for a sbc. & indeed they were $59. for $215. you could buy 2 sets of long cast 427 headers at Carlisle. Boy were my priorities wrong. And in 1980 I passed on a boss 9 for 6k at said Carlisle. Oh well.
Post by: fryedaddy on July 25, 2016, 06:05:13 PM
i put my header on and hooked it to my 3 inch x pipe and exhaust.ahhh the sweet sound of a fe going through a 3 inch duel exhaust with no leaks..man i could have swore i had a gremlin in my engine with a hammer beating on my parts.that hole in my header sure made it sound like a medal on medal noise.
Post by: gdaddy01 on July 25, 2016, 09:07:16 PM
way back in the 70s , I had a truck with headers on it , burnt a hole in the collector , took the truck to an old welder and he gas welded a Prince Albert can on it , no more problem , man , could that guy weld .
