FE Power Forums => Member Projects => Topic started by: afret on June 18, 2016, 07:34:10 PM
Title: Glass hood and hood pins
Post by: afret on June 18, 2016, 07:34:10 PM
Cut the hole in the hood for the shaker and stuck the trim ring on today.
(http://i151.photobucket.com/albums/s156/oldafretired/IMG_3797_zpslb1tigcn.jpg)
Next comes the holes for the hood pins.  The pin kit comes with a top plate and another plate which I assume goes below and receives the screws from the top plate with the fiberglass in-between.  The hood has two layers there though with space between the layers.  I think the steel hood is like that too and the bottom layer has a large round cutout so the bottom plate can fit against the bottom of the top layer.
(http://i151.photobucket.com/albums/s156/oldafretired/IMG_3798_zpszbgvibr8.jpg)
Should I make a cutout in the bottom glass layer like in the stock hood?
Title: Re: Glass hood and hood pins
Post by: cjshaker on June 18, 2016, 09:22:12 PM
You're right that the stock hood has a large somewhat oval cut-out on the bottom side. I have 3 hoods, one being NOS, and they all have that cut-out. Not so sure how it would work trying to go through both layers of fiberglass if there's space between them. I'd probably make a cut-out. The two plates would certainly spread the load out on the single layer of fiberglass, and I wouldn't think it would be a problem. Trying to tighten the 2 layers with a space between them would likely distort both sides and be very visible on top.
Post by: afret on June 18, 2016, 09:54:58 PM
Yeah, I think you're right.  I'm going to make a cut out on the lower layer.  Thanks!
