FE Power Forums => FE Technical Forum => Topic started by: barrys65cyclone on June 05, 2016, 03:45:07 PM
Looking for advice for my 1965 Galaxie 352 4v performance upgrade this is a driver for my wife and i to take some trips in so no strokers looking for mild performance increase and want to retain the stock Autolite 4100.....
I have a set of PI 390 short tubes to install.
would a performer 390 be of help ?
Hyd cam recommendation. [ auto trans 3.00 ratio ]
i was thinking mill the heads good valve job and mild port work.
Recurve distributor with electronic conversion.
You'll have to work smart with it to improve. 352, big car, 3:00 rear. Small hydraulic roller, less than 220 @ .050 needed. Think about a RPM or a 428 CJ iron intake, OR a ported Ed Performer. Real good valve job and milling a good idea. The stroker using your block at 4.030 is a win-win. If you are going to freshen it, you should do the real good valve job and spend the porting money on the 352 stroker parts. Stroke will be your friend in a 3:00 geared cruiser.
Blair Patrick
Thanks for reply I was thinking this cam http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=938&sb=2
3.25 gears & a 1850 holley with your headers will work wonders.
