FE Power Forums => FE Technical Forum => Topic started by: Heo on February 22, 2016, 12:58:45 AM
Is a 352 block Different than a 390?
you cant in most cases bore a 352 4.090??
Standard bore on a 352 is 4.00. Standard on a 360/390 is 4.05. You would have to get a sonic check but I don't think you'll find many that will go more than 4.05. We just took apart a supposed ".30 over 390". Sonic check turned up a .60 wall thickness.
As i suspected then
