FE Power Forums => FE Technical Forum => Topic started by: 2ndgear on February 02, 2016, 04:36:57 PM
I know this is a bit off of the subject FE but it is for a car with a FE engine in it. What I am looking to where would a guy get a snap in mounting plastic single contact light bulb socket. Like for the # 53 or # 57 bulb. I believed the older car had them for the dash lights. I think they were black plastic push snap in 2 wire. One wire is for power and the other one is ground. The socket needs to be plastic with its own ground wire because a metal socket would ground out and not turn off the oil pressure switch. Any help would be great. Thanks in advance
Summit Racing has them.
Here's one but if you search there's more:
http://www.summitracing.com/parts/rfw-pl01/overview/
Thanks rcodecj that is exactly what I was looking for.
