FE Power Forums => Private Classifieds => Topic started by: garyv on January 31, 2016, 05:01:10 PM
Let me know if anyone has anything.
garyv
I have two C3 timing covers...I don't see a date code on either one...The one off my 427 has 427R stamped in the top (????) no date codes that I can see tho...
I don't think they have a date code other than C3 or C4.
Probably either would be correct.
From what I have found the "J" heads date this as a 64 1/2 engine
let me know if you want to sell one.
thanks
garyv
I don't need the blue C3 one.Timing pointer is a bit different than my other C3 cover..Needs a good cleaning but I don't see any stripped or damaged holes.Was on a CJ I am doing so I yanked it off and put a C8 cover on it..
(http://i297.photobucket.com/albums/mm220/427Fastback/427%20cover%20004_zpsejyev0xx.jpg) (http://s297.photobucket.com/user/427Fastback/media/427%20cover%20004_zpsejyev0xx.jpg.html)
(http://i297.photobucket.com/albums/mm220/427Fastback/427%20cover%20002_zpslwfggzf0.jpg) (http://s297.photobucket.com/user/427Fastback/media/427%20cover%20002_zpslwfggzf0.jpg.html)
(http://i297.photobucket.com/albums/mm220/427Fastback/427%20cover%20003_zpsahgpw6bw.jpg) (http://s297.photobucket.com/user/427Fastback/media/427%20cover%20003_zpsahgpw6bw.jpg.html)
(http://i297.photobucket.com/albums/mm220/427Fastback/427%20cover%20001_zpsomnybz40.jpg) (http://s297.photobucket.com/user/427Fastback/media/427%20cover%20001_zpsomnybz40.jpg.html)
(http://i297.photobucket.com/albums/mm220/427Fastback/427%20cover%20005_zpsmdlt84i1.jpg) (http://s297.photobucket.com/user/427Fastback/media/427%20cover%20005_zpsmdlt84i1.jpg.html)
What you want for it?
garyv
Thinking $40.00 plus some shipping.....Keep in mind I am up in BC Canada.......Cory
Cory my zip is 25177 I'm in WV.
if you don't mind check to see what shipping would be
I have one coming from another member and I'll look it over.
If it doesn't work out I'll get back with you.
Chances are I still may take it depending on shipping charges.
garyv
