FE Power Forums => FE Technical Forum => Topic started by: FERoadster on January 22, 2016, 11:30:42 PM
Title: I've got a chance to buy a NOS Zoom aluminum FE Flywheel
Post by: FERoadster on January 22, 2016, 11:30:42 PM
for a decent price. Were they a well made product? I figure it was made in the late 70's-early 80's. 428 balance for my 428 crank.
On the FEForum my car weight and gearing/trans made it streetable. Car weight just under 3000#.
What's the quality? I'll be using a Lakewood Bell.
Richard >>> FERoadster
Title: Re: I've got a chance to buy a NOS Zoom aluminum FE Flywheel
Post by: Katz427 on January 23, 2016, 06:14:37 PM
Zoom was always a good brand back in the 70's / 80's. I remember that we used Zoom clutch and pressure plates in our oval track Ford with no problems. Should be a good flywheel.
Post by: XR7 on January 24, 2016, 01:53:50 AM
As long as it has a steel heat shield riveted on so it is replaceable, if it is bonded on, or not a steel or bronze face (solid aluminum...) then pass on it.
Post by: FERoadster on January 24, 2016, 05:24:12 PM
I did check and it is riveted
So I'm going ahead with the buy.
Thanks  FERoadster
Post by: FERoadster on February 19, 2016, 09:03:37 PM
Purchased the Aluminum flywheel and it arrived today.
Sold on HAMB as a Zoom flywheel but the casting and sticker both say Weber and it's stamped #52510
What's the quality of Weber vs. Zoom  and is the 52510 for a 428 balance? There are steel balance weights in the flywheel that are about the same location (180~ apart) as the holes drilled in my Ford 428 wheel. Got to check that closer-------------- It does have a riveted steel clutch facing.
Edit: Attached Pictures
Post by: jayb on February 20, 2016, 01:41:30 PM
Weber was a good brand back in the day; maybe Zoom purchased them or Weber was renamed or something?  I wouldn't be hesitant to use it because it says Weber on it...
Post by: cammerfe on February 20, 2016, 02:17:55 PM
+1 with Jay. 'Back when', Weber was as good as it got.
Post by: FERoadster on February 20, 2016, 06:37:52 PM
Jay and KS (Ken?) thanks. I had a Weber in one of my Model A's (SBC however) and it really revved quick. It was way too much a handful to drive with a 5.13 posi. Swapped to a 3.70 and SBF for a trip from Michigan to the Memphis Street Rod Nats. in 1975. The SBC is still on a stand in my shop here in Oregon.
Richard
