FE Power Forums => Non-FE Discussion Forum => Topic started by: machoneman on January 18, 2016, 03:50:30 PM
Title: New sensor proves T/F engines do over 10,000 hp/8,000 lbs/ft!
Post by: machoneman on January 18, 2016, 03:50:30 PM
Interesting blurb on how modern sensors 'prove' just how powerful these engines are. I'd expect similar versions for gas powered street and hot rod engines. Heck, this kinda' stuff would be helpful to all classes of racing and even Jay's FE powered cars. Woo-hoo for modern stuff!
http://www.dragzine.com/news/top-fuel-torque-sensor-reads-over-8000-lb-ft/
Title: Re: New sensor proves T/F engines do over 10,000 hp/8,000 lbs/ft!
Post by: shady on January 18, 2016, 04:59:32 PM
I wonder how they come up with a calibration?
Post by: machoneman on January 27, 2016, 09:45:00 AM
Don't know but I'd suspect it's done by some type of calculation, maybe an algorithm using known acceleration rates from nitro cars.
That or actual dyno time on say a blown alky engine (some have done this, like Double AA Dale Armstrong long ago btw) and then extrapolating the hp curve for a nitro engine. All speculation on my part however!
Post by: 57 lima bean on January 27, 2016, 03:33:40 PM
These have been around for years.   http://www.vericomcomputers.com/vc4000accelerometers.html
Post by: Qikbbstang on January 28, 2016, 03:30:21 PM
A couple decades ago in a Fueler power article in Hot Rod they detailed how the cams are ground 5, 10, 15 degrees off at each journal accordingly to make up for the crankshafts twisting under power ...............
   Also amusing how long AA/__ was able to run 9" axle housings.
