FE Power Forums => FE Technical Forum => Topic started by: country63sedan on March 02, 2012, 09:00:26 PM
Title: Powder coating question
Post by: country63sedan on March 02, 2012, 09:00:26 PM
I'm thinking about getting a do it yourself powder coating kit for stuff around here and since the wife needs a new stove anyway.......... ;D
  I was looking at the finned Ed valve covers in the shop, and they've got some gouges on the fins. Is there such a thing as "bondo" to be used under powder coating?  Thanks, Travis
Title: Re: Powder coating question
Post by: machoneman on March 02, 2012, 10:21:18 PM
Sorry but no. If you plan to powder coat those gouged covers, you'll need to skip the Bondo and weld them instead, then finish grind them before the powder coat step instead.
Post by: country63sedan on March 02, 2012, 10:47:34 PM
I didn't figure there was such a thing, but thought I would ask anyway.  Thanks, Travis.
Post by: 427Fastback on March 03, 2012, 12:59:34 AM
Actually there is...My Harley friends have been useing JB Weld...You have to use the slow cure.You can not use the fast cure 5 min stuff.I asked a local powdercoater if he knew of this and he said yes and it does work...I have not personally done it.You may want to check with your local coaters.......Cory
Post by: jayb on March 03, 2012, 01:23:32 AM
Wow, another unexpected use for JB Weld!  That stuff is almost as good as duct tape...
Post by: machoneman on March 03, 2012, 07:18:34 AM
Cool! Now that's one great idea that is much easier than welding.
Post by: country63sedan on March 03, 2012, 06:45:15 PM
That's awesome. I'll look into that. If it holds up, it would make a cosmetic repair under powder coat so much easier.  Thanks, Travis.
