FE Power Forums => FE Technical Forum => Topic started by: Chrisss31 on November 03, 2015, 09:02:46 PM
Title: Strokers
Post by: Chrisss31 on November 03, 2015, 09:02:46 PM
Hi all, first post from a new guy here.  I have some questions about FE strokers, or I maybe I'm just curious.  I have always admired the 427 for what it is, big bore/short stroke.  I know the obvious benefit to stroking is more cubic inches, but are there any other benefits to increasing the stroke?  Is it more beneficial for making power than a nice set of CNC ported heads?  I've not tinkered with car engines much, but I know with bike motors adding stroke usually made a really torquey motor that wouldn't rev much.  I always liked short stroke motors with a long broad power curve, would this principal apply here?
Title: Re: Strokers
Post by: jayb on November 03, 2015, 09:37:58 PM
Given the same number of cubic inches, a big bore, short stroke engine will rev better and make more power than a small bore, long stroke engine.  However, cubic inches trumps pretty much anything in HP/torque department.  So, if you go from a stock 3.78" stroke 427 to a 4.25" stroked 427, you will pick up 50+ cubic inches and the big motor will win every time.  It will make more power across the entire RPM band, and more torque, and will rev faster than the stock stroke 427 because of the increased power.  The reason the FE stroker kits are very popular is because they really don't have a downside, except for gas mileage.  And who cares about gas mileage?  ;D ;D
Title: Re: Strokers
Post by: Stangman on November 04, 2015, 02:16:31 PM
Amen, enjoy the gas prices while we can
Title: Re: Strokers
Post by: Chrisss31 on November 04, 2015, 07:59:46 PM
The old "no replacement for displacement"!  Thanks for the explanation.
Title: Re: Strokers
Post by: plovett on November 04, 2015, 08:24:31 PM
Oh man, I hate that phrase.   People seemingly never compare a smaller, higher rpm, engine, with a lower gear, to a bigger lower rpm engine, with a higher gear, and otherwise ALL the same components.  They seem to always change some of the components and variables, but not all of them in unison.
I say if your engine builder's philosophy is a one sentence rhyme, you need an engine builder with a more complicated philosophy.  Then again, building big is easier and more forgiving of all the small mistakes made.
JMO,
