FE Power Forums => FE Technical Forum => Topic started by: Autoholic on October 08, 2015, 07:07:39 PM
Title: SOHC Distributor
Post by: Autoholic on October 08, 2015, 07:07:39 PM
I've been continuing my research on this engine and I've come across some conflicting information when looking for the original distributor information. I know that it used a dual breaker transistorized ignition with only mechanical advance. For a drag racing application, vacuum advance is useless. The conflicting info I run into is the part number. The shop manual says C5AF-12127-BY and I've found from more than one reference (however not an official one) online that the SOHC had a C5AF-12127-AZ part number. I haven't been able to find actual pictures of the BY unit but have found pictures of the AZ unit. I know that the body of the distributor was the same, the last letter(s) indicate how the timing was setup. Any insight on this is appreciated.
Title: Re: SOHC Distributor
Post by: Autoholic on October 08, 2015, 07:20:46 PM
Never mind, I found the answer from a long time ago on here.
http://fepower.net/simplemachinesforum/index.php?topic=368.0
Post by: Autoholic on October 08, 2015, 07:46:02 PM
I've also found information that suggests a -AV part number for the distributor. The example I found on this has a date code of 7C26, which means 1967 and could be legitimate if Ford decided to come up with a new part number for Autolite branded units built in '67. The BY was a FoMoCo unit and the AZ unit was both, as Ford switched from FoMoCo to Autolite branding in Nov of '66.
Post by: cammerfe on October 10, 2015, 01:01:06 AM
Transistorized ignitions from that period used a single set of points, to the best of my knowledge. At least my own did. The purpose of dual points is to offer a path to increased dwell with one set of points being the 'make' and the other set being the 'break'. I believe dwell in a transistorized system is handled in a different manner.
