FE Power Forums => FE Technical Forum => Topic started by: jimeast on September 28, 2015, 08:32:23 AM
Jay, I have the book, extremely helpful.
I have a 390 stroker to build and a 427 block that will be built after the 390. I'm curious about the idling conditions and street-ability of the 390 stroker and 427 (non-stroker) dyno mules you built. I suspect the cams you used are a little too aggressive for most street rides, but thought I'd ask. And if you have any data, I'd be curious about the general vacuum conditions these two dyno mules delivered.
I don't have vacuum data on those engines, but with the cams used in them you can figure that the vacuum would probably not be enough for power brakes; you'd have to have an auxiliary vacuum source if you need the vacuum for power brakes. As far as streetability, I think that is pretty subjective. To me they are both easily streetable, but not everyone would agree. They both idle right around 1000 RPM, and you'd want a 3500 stall converter to run them on the street (or a stick).
I think you could take either one of those engines and convert them to a milder hydraulic roller, and get the vacuum up where you want it for power brakes while maintaining or increasing horsepower on the 390 stroker engine, and probably not losing a whole lot on the 427.
