FE Power Forums => FE Technical Forum => Topic started by: StangYellow on August 17, 2015, 09:17:01 PM
Title: Different size timing cover bolts?
Post by: StangYellow on August 17, 2015, 09:17:01 PM
All 8 of my ARP timing cover bolts are the same size, but the bottom 4 holes are larger than the bolts. I haven't been able to find my ziplock baggie of original bolts yet to check them out. Needless to say... I'm stuck. Anyone experienced this before?
Title: Re: Different size timing cover bolts?
Post by: drdano on August 17, 2015, 10:08:49 PM
Sounds about right, 4 of the bolts are a larger diameter on the bottom of the cover.
Post by: cjshaker on August 17, 2015, 11:01:42 PM
Typical for ARP. Very few of their "engine specific" kits are 100% correct, so you have to spend more to get the correct ones. Often times they need modified (shortened) also. Their intake bolt kits are often wrong length on a few,  header bolts are too long, flywheel bolts are often too long, front cover bolts as you found out, etc.
Post by: StangYellow on August 18, 2015, 06:59:30 AM
Oh boy, so I have a lot to look forward to with this complete set. I didn't pay much attention to the cover bolts when removing them, so I didn't notice the difference. Looks like I will be tearing the garage apart for my original ones
Post by: StangYellow on August 19, 2015, 11:27:18 AM
Does anyone happen to know the length/thread/pitch of these bolts? Seemed to have misplaced these during the disassembly. I called ARP to see if they happened to know about this, and they didn't. I need to call in and order the correct ones from ARP
Block and cover are a '66 390....
Thanks!
Post by: Nightmist66 on August 19, 2015, 12:27:55 PM
The bottom 4 bolts are 3/8-16 thread and the others are 5/16-18 thread. As far as lengths, I don't know off the top of my head and am not sure when I could measure mine. If you need the measurments right away and no one else jumps in, figure on a good 1/2" thread going into the block, another 3/16" for the washer and gasket,and whatever else the timing cover measures. Good luck. ;)
Post by: thatdarncat on August 19, 2015, 01:09:04 PM
The original Ford spec for the bolts are 3/8"-16 x 7/8" long and 5/16"-18 x 3/4" long. Also just as a bit of trivia, the originals were a "locking" bolt, they have a small nylon pellet imbedded in the threads to keep them from backing out.
Post by: StangYellow on August 20, 2015, 06:37:15 AM
That's a huge help guys. Much appreciated!
Post by: cjshaker on August 20, 2015, 08:05:27 PM
Come on, you called to find out what type of bolts it uses, from the guys who got it wrong the first time?...lol
Just razzin ya, but I thought that was humorous  ;D ;D
