FE Power Forums => Private Classifieds => Topic started by: chilly460 on July 08, 2015, 12:45:51 PM
Title: T10 setup for Galaxie
Post by: chilly460 on July 08, 2015, 12:45:51 PM
I have a narrow pattern bell, fresh T10, new Hurst shifter and rods, flywheel, and aluminum driveshaft to put a T10 in a 60-64 Galaxie.  Trans was behind a mild 390, street tire open diff car, not abused.
I just pulled this out of my '63 Marauder, approximately 500miles on the setup, less on the driveshaft.  I found a great deal on a TKO500 so went that way.
T10 rebuilt by me, all new bearings, sliders, synchros and 2-4th gears purchased from Ed Hartnett.  First is a little noisey but otherwise it shifts great, absolutely doesn't pop out of gear.
Hurst shifter was new at time of install, bought it from Dan Williams, along with the rod kit, setup cost $500.
Bell has partial chipped ear but otherwise perfect, doesn't effect install.
Driveshaft is a 3.5" aluminum Shaftmaster with 1330 joint and new Spicer yoke and ujoints.
$600 obo, I'm in Virginia but travel to Pa frequently and would deliver to mid atlantic for the right situation.
PM with any questions, thanks.
Title: Re: T10 setup for Galaxie
Post by: shady on July 08, 2015, 05:36:08 PM
now there 's a deal boys & girls, & it's not on the west coast as usual. If I didn't already have 2 stick setups I'ld be all over this. However I am in central pa, & would gladly be the middleman if somebody up north would want this. NO charge.  & in spite of my name I am trustworthy.
Post by: troublemaker427 on July 21, 2015, 06:16:38 AM
PM sent...
Post by: troublemaker427 on July 24, 2015, 07:38:07 AM
PM sent again...
Post by: chilly460 on July 24, 2015, 10:50:12 AM
Email sent
Post by: 428kidd on July 30, 2015, 10:08:37 PM
I sent you a PM as well.
Post by: ford63fe on March 12, 2016, 08:33:07 AM
CHILLY  ---sent you a message on the tko 500 don't know if u got it---need to talk to u about this--if u can call me anytime --have some install questions---thanks mark---920-980-1211==im in sheboygan wi
