FE Power Forums => FE Technical Forum => Drag Strip Results for FE Powered Vehicles => Topic started by: fallguy72 on June 14, 2015, 11:53:54 PM
Performance Summary:
1/4 mile ET: 12.872 1/4 mile MPH:102.17
1/8 mile ET: 8.151 1/8 mile MPH:83.90
60 foot time:1.786
Track: Ashcroft B.C. Canada
Weather Conditions: 29c
Vehicle Use:street car with one trip to the track per year
Vehicle Specifications: stock gta "S" code
Model Year:1966
Model:Fairlane GTA
Style:2dht
Engine Details (link to post in Dyno Results board if available: 445 cid, stock 66gt heads c6ae u, comp cams 280h 230/230@.050 530 lift, 9.8 cr, performer rpm manifold, fpa headers, holley 750 dp
Transmission: c6 with transgo shift kit
Torque converter details (if automatic):3000 stall tcs converter
Clutch details (if manual):
Driveshaft stock weak link broken in half with damage to floor pan
U-joints:regular stock
Rear end type:stock
Differential type:mini spool
Gear Ratio: 3.89
Axles: moser 28 spline
Front tires:225/60 15
Front wheels:centerline
Rear tires: m/t et street 255/60 15
Rear wheels:centerline
Front suspension information: stock
Rear suspension information: stock
Ready-to-race vehicle weight, including driver:3596 lbs
sounds like a cool cruiser,those stock shafts can be dangerous w/sticky tires!
https://www.youtube.com/watch?v=R0l1ANM-NKE https://goo.gl/photos/yrygc9i65v1togtLA https://www.youtube.com/watch?v=UWRx4xPVl4Q
Kool Vid!
Thought you had him with the hole shot, but he nipped you on the big end.
Your gonna need a bigger cam. ;)
