FE Power Forums => FE Technical Forum => Topic started by: BigBlockFE on June 09, 2015, 04:39:37 PM
Title: Felony heads vs edelbrock
Post by: BigBlockFE on June 09, 2015, 04:39:37 PM
I have been reading about the new felony head by Survival, is this the way to go for a 482 street build or are the edelbrocks cheaper and just as effective.
Title: Re: Felony heads vs edelbrock
Post by: My427stang on June 09, 2015, 05:12:27 PM
Depends on the build, and I have not had my hands on a set yet but
1 - Edelbrock is cheaper
2 - Edelbrock will not be as effective as the Felony heads as the performance level climbs.  As the rpm and power climbs even more, the Felony heads will have an even greater margin
Post by: BigBlockFE on June 09, 2015, 05:49:17 PM
I thought that for a 575hp street build the edelbrocks are fine a tested, I also read where the felony heads make for a perfect street head between 2500 and 5500 rpm, for drivabilty and power due to there design. Its cool to see so many different options now...
Post by: My427stang on June 09, 2015, 06:32:24 PM
I think you'd find a 575 horse Edel headed 482 would be a 600+ horse 482 after the head swap
Post by: BigBlockFE on June 09, 2015, 07:35:13 PM
The felony heads ported will be a nice addition to the street strip market. And the Ed heads ported are always a great option for power.
Post by: Joe-JDC on June 09, 2015, 09:10:31 PM
On a 482, you are going to have to do some serious porting to get 575hp out of a set of Edelbrock heads.  That will require the heads and intake to flow well together, and a serious camshaft.  300-310cfm would be the target flow number to reach 575hp with Edelbrock heads.  You can get there easier with the Survival head on a 4.250" bore.   310cfm is also easier to obtain with porting the Survival head.   Joe-JDC
Post by: BigBlockFE on June 09, 2015, 09:38:03 PM
I believe all the hydro rollers Kraft builds with his stage 2 heads all reach the 575hp level or close to if not more. Those are Ed heads ported. I could be wrong. I think the felony heads are sweet.
Post by: Joe-JDC on June 09, 2015, 09:54:50 PM
KC Stage II heads are CNC ported, and usually have 2.150 or larger intake valve, depending on which head you ask him to start with.   The last three sets I have flowed on my SF-600 flowed in the 335-340cfm range at .750".  Joe-JDC
Post by: BigBlockFE on June 09, 2015, 10:43:29 PM
So if you don't have your own machinist port the heads you can just order them already done.  Do most guys get the port work done themselves or just order the heads already done. I realize it depends on the build.
Post by: Joe-JDC on June 09, 2015, 11:40:41 PM
You mentioned the KC II heads, so I just wanted to make sure you realize they are CNC ported.  He will build the heads however you desire.  Barry can supply his Survival heads with CNC porting, also.  There are not a lot of folks left who can hand port the FE heads to be competitive with the CNC pricing or flow numbers.  Joe-JDC
Post by: BigBlockFE on June 10, 2015, 12:22:10 AM
I know they are ported, I said that in my previous threads, any good machine shop can port  heads, I would rather have a machine do it, Keith's 482 comes with the stage 2 head, I want to know what that engine will do with the felony heads, same port...im building an engine now and I love the Head options that I have to choose from...
Post by: Barry_R on June 10, 2015, 04:55:25 AM
I have a rather obvious bias.  But I also have data.  I have not done a 482 "mule" to try a bunch of variations, but I have done enough engines to show up the trends.  Use the dyno numbers as guidance.  My dyno installation is different than others and the values may not be the same.  Different does not mean "wrong" - it means different.  I have an older DTS 8800 dyno, run through mufflers (nice area), and run the mechanical water pump with a belt in place, shop air for inlet and room ventilation, and no airflow cone on the carb.
The off the shelf Edelbrock head is likely to be 30 or so HP less than the "as cast" Survival head in the same application.
A slightly modified Edelbrock head (like our Stage X - valves, valve job, bowl work) will reduce the power peak difference, but will still be a small amount weaker - maybe 10 HP less.  The Survival head will make more torque and have a greater advantage "off peak" requiring a couple degrees less timing.
A more highly modified Edelbrock with porting will exceed the Survival head in its "as cast" condition.  Our CNC ported Edelbrock flows around 324-329 cfm and will get up around 600HP in applications where the "as cast" Survival head goes around 570ish.  I have had a couple pump gas 600HP 482 engines with the as cast head but they were solid roller and/or Dominator carb pieces.  I've tried to hit 600 with hydraulic roller cams and 4150 carbs lately but instead seem to have gotten even more torque, a flatter curve, and the same 570ish power numbers.
Doing a full port effort on the Survival head will approach 370 cfm (CNC or otherwise) and puts you into a different zone as far as power potential for a traditional medium riser configuration that can still use normal bolt on rockers and no welding.  But the cost also move up there as well.
And the downside is that I am out of castings and will be for quite a while.  So if your intent is to get something running in the short term you will need to go to an alternative - like the modified Edelbrock.
Post by: blykins on June 10, 2015, 05:32:59 AM
I suppose I've had my hands on about every head out there....CNC Pond, Edelbrock, CNC Edelbrock, hand-ported Edelbrock, BBM, Barry's as-cast heads, and Barry's CNC heads.
I will be dyno'ing a 482 on Friday with BBM as-cast heads, but it probably won't be indicative of a "performance" engine as it's for a towing application.
With that being said, from what I've seen so far, Barry's heads would be one of my top picks if given the option.   I didn't get a chance to flow the as-cast head like I wanted, but his CNC head went 370 on the SF600 down here, had great velocity and a quiet port.  I just did a 511 with his CNC heads, out of the box Blue Thunder 1x4 MR, and a mild-ish hydraulic roller and cracked 616 hp and 671 lb-ft of torque.
If Survivial is out of heads and won't have any, then my next choice would be a CNC Pond head.  The Pond head probably has some of the highest performing exhaust ports that I've seen and will flow around 340-350 on the intake side.  These will only work on a big bore engine though, so the 390/428 crowd is out.
A 482 with Pond heads, hydraulic roller, and Performer RPM intake should be around the 570-580 hp mark on the dyno I use.
Post by: Drew Pojedinec on June 10, 2015, 06:17:34 AM
Focusing on just air flow and hp made is cool, but I think it misses a few of the details that make these newer heads so much better.
The new wave of cylinder head designs like Barry R's FElony heads have much more engineered into them.  The combustion chamber is much better, the burn will happen quicker and require less timing, the burn will be more efficient as well.  Their flow into and out of the ports should also be smoother, and have a higher velocity at the same amount of flow.  I would suspect that if an Edelbrock head with 300cfm of flow vs a FElony head with 300cfm of flow, I'd rather street drive the FElony head, as I suspect it'd be a better performer at just about any throttle position.
Not trying to knock Edelbrock, but since BBM, Barry R, et el came out with these new heads, I feel Edelbrock is falling more into the "stock replacement with more power potential" category.
*Of course this is theoretical based on what I understand of air flow in engines, I have no direct experience with the parts in question*
Post by: BigBlockFE on June 10, 2015, 06:46:28 AM
Great info, its nice to see so many new options, the track is the real dyno, numbers are just numbers, 550-600hp is all the same to me to a point...I use the dyno for tuning anyway...how long are you put of the heads for Barry...
Post by: Barry_R on June 10, 2015, 10:54:43 AM
Its at least 8 weeks and probably longer - since all the parts that are normally inventory items at my suppliers seem to be out of stock these days I cannot imagine they'll push a custom order head casting to the front of the line.
At this point in the year - at one time or another - certain suppliers have been out of:
H beam rods
I beam rods
crankshafts
heads (that's me...)
hydraulic roller lifters
intake manifolds - both BT and Edelbrock...
oil pans
oil pump pickups - (but not at the same time as the pans...)
rocker arms
Mallory metal (to balance cranks)
head bolts - yes head bolts!
valve covers
damper spacers
blocks
None of this stuff has been at all predictable - you find one missing item and then discover another key part is out.
I really believe that manufacturers cut way, way back on people and inventory during the economy crunch - and now that things are finally coming back they have no way to respond to the growing demand...  Right now I am using three large warehouse groups plus manufacturer direct on many parts and still waste a huge amount of time chasing stuff.
Post by: thomassjølimartinsen on June 10, 2015, 11:59:11 AM
Hi Barry, sorry to brake in here, but i see you mention your supplier are out of crankshafts and rods is thats way the stroker kit i ordered aint send yet?
In that case i will put the mails and phone calls on hold for a while, but
Are we talking couple of months before you get it?
Greetings Thomas
Post by: thomassjølimartinsen on June 10, 2015, 12:04:50 PM
Greetings Thomas
  ment "why" .. sorry for bad typing  :o
Post by: Barry_R on June 10, 2015, 03:37:39 PM
Right now I have cranks...but have been out of pistons for a while.
Pistons are due to ship end of this week/beginning of next.
Scat just confirmed they had I beam rods but were out of H beams.
I found H beams at a regional warehouse & bought all they had - - just wonder whats next?
Post by: thomassjølimartinsen on June 10, 2015, 03:41:04 PM
Thats sounsd great, maybe the kit will be ready in a couple of weeks a month maybe?
Post by: BigBlockFE on June 10, 2015, 11:23:08 PM
Sounds like some popular head if you ask me...or heads... :D
Post by: Stang527 on February 14, 2018, 03:20:25 AM
On the cnc ported felony head does anyone no what intake will fit the port
Post by: Barry_R on February 14, 2018, 06:25:53 AM
We have put Victor, Tunnel Wedge, Blue Thunder single four, and Performer RPM intakes on them.
The Victor is easiest, but they all require some port work to match up.
