FE Power Forums => Private Classifieds => Topic started by: fairlanebob on May 31, 2015, 09:36:31 AM
Title: Fresh 30 over 390 for sale
Post by: fairlanebob on May 31, 2015, 09:36:31 AM
FRESH .030 OVE390 FORD MOTOR FOR SALE
 SHORT BLOCK:
 390 BORED .030 OVER
 TRW FORGED PISTONS 10:3 COMPRESSION
 CRANK STD ON RODS/MAINS
 ROD BEAMS GROUND AND POLISHED, RESIZED AND REBUSHED ON LITTLE END
 ARP ROD BOLTS
 COMPLETE COMP CAMS KIT: 292 MAGNUM HYD CAM/LIFTERS, SPRINGS/RETAINERS/KEEPERS,
 TIMING GEARS & CHAIN, COMP CAMS MAGNUM BALL/CUP PUSHRODS
 MELLINGS HI-VOLUME OIL PUMP, ARP HARDEN OIL PUMP DRIVE SHAFT
 DOVE REMOTE OIL FILTER BLOCK W/REMOTE OIL LINES AND FILTER MOUNT
 *** I CAN SUBSTITUTE A FACTORY OIL FILTER MOUNT IF WANTED***
 NEW OIL PAN
 COMPLETE ROTATING ASSY HAS BEEN BLUEPRINTED AND BALANCED
 HEADS:
 PORT MATCHED TO GASKETS
 2.09 IN 1.66 EX STAINLESS CJ VALVES WITH HARD SEATS
 DOVE ROLLER ROCKERS, SOLID SPACERS,NEW ROCKER SHAFTS
 ANSEN POLISHED ALUMINUM PENTROOF VALVE COVERS
 *** IF GOING IN A CAR WITH POWER BRAKES THESE MAY NOT WORK,
 I WILL ADJUST THE PRICE ($100) IF NOT NEEDED ***
 EDELBROCK PERIOD 2-4 INTAKE (F262)
 2 EDELBROCK 1405 600 CFM CARBS (NO CHOKES)
 NEW EDELBROCK 2-4 AIR CLEANER
 NEW MALLORY UNILITE DISTRIBUTOR
 NEW SUMMIT 8MM SPARK PLUG WIRES
 ALL PULLEYS, BELT (1) AND ALTENATOR COME WITH MOTOR
 MOTOR HAS 2 GROVE CARNK/WATER PUMP PULLEYS FOR POWER STEERING IF APPLICABLE
 ***WHAT DOES NOT COME WITH THE MOTOR:
 MINI STARTER...BUT WILL HAVE A FACTORY STARTER ON IT
 HEADERS
 LAKEWOOD BELLHOUSING
 ***I DO HAVE A FACTORY FE STICK BELLHOUSING (FOR USE WITH SMALL IMPUT SHAFT TRANS),
 BLOCK PLATE, INSPECTION COVER, CLUTCH DISK AND PRESSURE PLATE (HAS LESS THAN 1 THOUSAND MILES USE)
 I HAVE A STICK FLYWHEEL ON THE MOTOR FOR RUN PURPOSE WHICH COMES WITH THIS PACKAGE***
 MOTOR IS ON MY ENGINE TEST STAND SO YOU CAN SEE AND HEAR IT RUN
 MOTOR HAS ABOUT 1 1/2 HR RUN TIME (as of 5-30-15) TO BRAKE IN CAM AND MAKE ALL ADJUSTMENTS
 MOTOR IS READY TO GO IN YOUR CAR OR TRUCK
 I HAD THIS MOTOR BUILT FOR MY 66 FAIRLANE GT BUT FOUND A 67 SHELBY 428 MOTOR INSTEAD
 THAT IS OUT BEING BUILT
 I HAVE OTHER PICTURES IF NEEDED
 $4850 FOR ALL OR $4500 FOR MOTOR
 BOB ELLIS
 bellis@isoc.net
 513 600 7213 I DO NOT TEXT VERY WELL SO PLEASE DO NOT TEXT ME I JUST HAVE AN OLD FLIP PHONE
Title: Re: Fresh 30 over 390 for sale
Post by: 1967F250CS on July 27, 2015, 11:22:02 PM
Still have this? Would you be willing to part with the short block only? I have heads and intake and the other items already.
Robert
