FE Power Forums => FE Technical Forum => Topic started by: CDXXVII on January 12, 2012, 09:47:19 PM
Any down side to the 8554 PT head gasket on a street 427 with a standard bore and iron heads?
What's the up side of the Ford Racing head gaskets? Is it because they can accomodate a large overbore?
The Ford Racing/Fel-Pro 1020 gasket has a flattened steel fire ring around the combustion chamber that does a better job of sealing under high pressures. The passenger car gasket you mention will work perfectly fine in a moderate street application - something under 500HP should be no big deal. I just like having extra insurance....
be carefull on headgasket/bolt/stud choice, let your compression ratio determine, not price
Dean, are you holding back a story here? Which gasket was it that failed on you? Why?
Factory compression is about 11:1.
Barry, would the fire ring on the high pressure gasket aggrivate problems with valve seat distortion when torquing the head bolts on iron heads?
felpro 1020 with factory bolts and iron heads, 12.9 static compression
