FE Power Forums => FE Technical Forum => FE Engine Dyno Results => Topic started by: blykins on May 09, 2015, 07:18:20 AM
Performance Summary:
Cubic Inches: 511 Dyno brand: Stuska
Power Adder: N/A Where dynoed: Dale Meers Racing Engines, Buffalo, KY
Peak Horsepower: 616
Peak Torque: 671
Horsepower and Torque Curves:
Engine Specifications:
Block brand, material, finished bore size, other notes: Pond aluminum, 4.310" bore
Crankshaft brand, cast or forged, stroke, journal size: RPM 4340, 4.375", .010/.010
Connecting Rods brand, material, center to center distance, end sizes, bolts: Scat H-beam, 6.700
Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR: Racetec 20cc dish, 10.5:1
Main Bearings, Rod Bearings, Cam Bearings brand and size: FM 146M10, FM 8-7200CH10, Durabond
Piston rings brand, size, other notes: Mahle 1.5/1.5/3mm
Oil Pump, pickup, and drive: POP Blueprinted Melling HV
Oil pan, windage tray, oil filter adapter: Moroso T-sump
Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"): Custom Comp Cams hydraulic roller, 251/257 @ .050", .635/.607" lift, 110/104
Lifters brand, type: Morel
Timing chain and timing cover: Ford Racing/factory
Cylinder heads brand, material, port and chamber information: Survival CNC heads
Cylinder head flow in cfm at inches of lift (28" H2O pressure drop):
Intake Exhaust
.100 .100
.200 .200
.300 .300
.400 .400
.500 .500
.600 .600
.700 .700
.800 .800
Flow bench used, location:
Intake valve brand, head size, stem size: SI 2.250, 11/32
Exhaust valve brand, head size, stem size: SI 1.750, 11/32
Valve springs brand, part number, specs: Comp Cams 26055
Retainers and locks brand, part number, specs: Comp 703
Rocker arm brand, type (adjustable or non-adj), material, ratio: T&D street
Rocker shafts and stands, brand, material:
Pushrods brand, type, length: Trend 5/16, .080"
Valve covers, brand, type: Ford Racing
Distributor brand, advance curve information: MSD Pro Billet
Harmonic balancer brand: Powerbond SS
Water pump brand, type (mechanical or electric): Edelbrock
Intake manifold brand, material, porting information: Blue Thunder 1x4
Carburetor(s) brand, type: Quickfuel BDQ-850
Exhaust manifolds or headers brand, type:
Great torque number on that engine, Brent...
It would be very interesting to see the charts.
(http://i170.photobucket.com/albums/u267/shellvalleyowner/photo%20118_zpsnek6beia.jpg)
(http://i170.photobucket.com/albums/u267/shellvalleyowner/photo%2037_zpscqufvjrq.jpg)
(http://i170.photobucket.com/albums/u267/shellvalleyowner/photo%20216_zpsqmgczjd6.jpg)
(http://i170.photobucket.com/albums/u267/shellvalleyowner/photo16_zpsaketrm6j.jpg)
(http://i170.photobucket.com/albums/u267/shellvalleyowner/photo%2044_zpsjgw01u9m.jpg)
(http://i170.photobucket.com/albums/u267/shellvalleyowner/photo%20119_zpsuy7vpc4j.jpg)
(http://i170.photobucket.com/albums/u267/shellvalleyowner/photo%20217_zpssrpwfvrl.jpg)
The graph shows a hp peak of 6000, but I think the graph indicates more of what happens through the entire run, even when the operator starts backing off the water valve (it's a Stuska). I would go by the tabulated chart; I think it's more accurate in this case. This is a little cooler water temp than what I usually run, we were previously hitting it at 170-180 degree water temp, but we had cooled the water back down right before this pull and just went ahead and ran it.
Remarkable torque curve. I've been reading about the influence of primary header diameter on peak torque RPM. Not sure I understand it, but curious what the header diameter was on that pull.
2"...
This is such a cool build, I'm very curious what the idle was like.
RPM, it work ok with power brakes?
