FE Power Forums => FE Technical Forum => FE Engine Dyno Results => Topic started by: blykins on May 07, 2015, 05:55:42 AM
Performance Summary:
Cubic Inches: 496 Dyno brand: Stuska
Power Adder: N/A Where dynoed: Dale Meers Racing Engines, Buffalo, KY
Peak Horsepower: 683
Peak Torque: 600
Horsepower and Torque Curves:
Engine Specifications:
Block brand, material, finished bore size, other notes: Pond aluminum, 4.310" bore
Crankshaft brand, cast or forged, stroke, journal size: Custom Scat Superlight, 4.250", 2.100" rod journal
Connecting Rods brand, material, center to center distance, end sizes, bolts: Oliver 6.700"
Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR: Diamond forged, moly coated skirts, 11:1
Main Bearings, Rod Bearings, Cam Bearings brand and size: Clevite coated, MS1010HXK, CB663HNXK, Durabond
Piston rings brand, size, other notes: Total Seal .043/.043/3mm
Oil Pump, pickup, and drive: POP Blueprinted Melling HV
Oil pan, windage tray, oil filter adapter: Aviaid
Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"): Custom Comp Cams solid roller, 270/280 @ .050", .438/.436 lobe lift, 112/106
Lifters brand, type: Crower bushed
Timing chain and timing cover: Ford Racing/factory
Cylinder heads brand, material, port and chamber information: KC Stage 3 Edelbrock
Cylinder head flow in cfm at inches of lift (28" H2O pressure drop):
Intake Exhaust
.100 .100
.200 .200
.300 .300
.400 .400
.500 .500
.600 .600
.700 .700
.800 .800
Flow bench used, location:
Intake valve brand, head size, stem size: Custom Ferrea 5/16 stem, 2.250"
Exhaust valve brand, head size, stem size: Custom Ferrea 5/16 stem, 1.76
Valve springs brand, part number, specs: PAC 1299, 285/720
Retainers and locks brand, part number, specs: Comp 733, 610
Rocker arm brand, type (adjustable or non-adj), material, ratio: T&D Race
Rocker shafts and stands, brand, material:
Pushrods brand, type, length: Trend 7/16 double taper
Valve covers, brand, type: Blue Thunder
Distributor brand, advance curve information: MSD Pro Billet
Harmonic balancer brand: ATI
Water pump brand, type (mechanical or electric): Edelbrock
Intake manifold brand, material, porting information: Dove Tunnel Wedge
Carburetor(s) brand, type: Quickfuel
Exhaust manifolds or headers brand, type:
