FE Power Forums => FE Technical Forum => Topic started by: rcodecj on December 15, 2011, 04:20:49 PM
Title: Fel-Pro 90145 intake gasket
Post by: rcodecj on December 15, 2011, 04:20:49 PM
Is the Fel-Pro QMS90145 intake gasket ok for PI intake and Edelbrock heads?
Here's a link:
http://www.summitracing.com/parts/FEL-MS90145/
Title: Re: Fel-Pro 90145 intake gasket
Post by: ScotiaFE on December 15, 2011, 06:18:46 PM
Yes it can be used.
I kinda like them. They are a good long haul gasket.
Can't really say how they line up on a PI, but should be ok.
I never use end seals on the intake to bulkhead ends. Only silicone on the ends and a smear around the water ports.
Make sure you snug the intake down good after the first heat cycle.
(http://i135.photobucket.com/albums/q128/ScotiaFE/gaskets004.jpg)
Post by: rcodecj on December 15, 2011, 06:43:28 PM
If I recall correctly, the PI intake matches the top and is shorter on the bottom. The sides I don't remember.
