FE Power Forums => FE Technical Forum => Topic started by: bn69stang on December 07, 2014, 05:15:35 PM
I am gathering all the parts i need to do the center section setup , and my question is matching the yoke thats currently under the car so my drive line length stays the same . It measures right at 3.5 inchs from dust cover to the center of the u joint , would that be the long yoke ? ..Bud
I guess i should add that the third member in the car now is a factory n case with 3.50 s and a trac loc , and daytona pinion support and has the collar mounted with the pinion support bolts , with a rubber stop on the top . I want to keep it all together , and not sure what it came out of . Thanks Bud
