FE Power Forums => FE Technical Forum => Topic started by: drdano on November 16, 2011, 10:52:56 AM
I'm looking at adding a shelf baffle to the front of my stock '62 oil pan. Does anyone have the dimmensions of one from say a canton or milodon standard capacity pan? The width is a given, but I'm not sure how long towards the front of the pan it should extend. Depth from the pan mounting surface would be nice to know too.
Here is the Milodon stock replacement pan.
http://www.summitracing.com/parts/MIL-30740/?rtype=7
Summit has a pan for 49.95 and I think it has a better baffle than the Milodon.
http://www.summitracing.com/parts/SUM-G3537/
Or you can hard tack a baffle in your pan
You have to come out from the slope about 3 inchs at the 3 1/2 to 4 quart level.
Make sure you clamp it down square or bolt it to a block well welding.
It can and will twist up on you and then it will leak more than it already does.
I like the shelf type baffle of that Milodon pan better than the other early CJ style of the Summit pan. I think I'll use your technique of finding where 3-4 quarts level is in the pan and place the baffle between the two levels. I think their technique of not welding the plate all the way in, but leaving a few spots open for drainback will work good and should keep the oil from pooling on the wrong side of the baffle.
Thanks for the links and photos, this is a big help. I'll post some photos of the baffle when I get it done.
