FE Power Forums => FE Technical Forum => Topic started by: frankenfords on June 28, 2014, 10:20:00 AM
Title: ?? Help Identifying Fairlane/Torino/Mustang Race Headers ??
Post by: frankenfords on June 28, 2014, 10:20:00 AM
I posted on the other forum as well, I hope this isn't considered spam.
I recently picked up some parts, including 2 pairs of FE headers. One set is a pair of lightly used old style Hooker 6113's (they have the part number stamped in the flange, but don't look like the pictures I'm finding on the web, as they have 1 7/8 inch primaries and the tubes for 5 and 6 do not go under the crossmember, and only the tube for 7 is a slip fit), and the other pair are unknown, unused race headers.
 The unknowns have 1 7/8 inch primary tubes, and the tubes for 1, 2, 5, and 6 are slip fits that go under the crossmember but each side has a conjoined flange. The tubes for 3, 4, 7, and 8 are welded to the collectors, and have sweeping bends similar to the Hooker 6375's, I assume an attempt to make the lengths closer to equal?
 The flanges on the mystery headers at the head are odd, in that they appear to be adaptable to either CJ heads with a higher port outlet, or GT heads with a lower port outlet. The flange at 1, 4, 5, and 8 has a top hole drilled closer to the top of the tube, and a shorter overall height (think CJ). The flanges at 2, 3, 6, and 7 have a taller flange, with the top hole drilled farther away (think GT). I am thinking this is so that the headers can be fitted, then the non-matching pattern slotted to work? Another oddity is that they have only the offset bolt holes for coil tower type heads, and none of them are slotted. There is not a lower row of bolt holes. So there are only 12 bolt bosses for the heads on each side. The Mr Gasket 254G gasket has an almost identical pattern.
 I know these are old, as they have a 3.5 inch collector with a square 4 bolt flange. The collector necks down to a 3 inch diameter just before the flange. This is a similar design to the Hooker truck headers for FE's (the neck down that is), but with a factory welded flange and a larger diameter. Another cool thing is these have the impossible to find 4 bolt reducers, and unused gaskets!
 Any help in identifying these would be appreciated. I am starting to think they might be Appliance or Blackjack headers based on the square collector flange? Anyone have any experience with these?
I tried to post pictures, but the pictures I took are too big to post.
 I feel I should add, at the risk of offending some (apologies in advance), that I will likely be selling these oddities from yesteryear once I have positive id on them.
Thanks in advance, Brett
Title: Re: ?? Help Identifying Fairlane/Torino/Mustang Race Headers ??
Post by: fe66comet on June 29, 2014, 10:43:31 PM
I have a friend with a 385 in a Torino and the headers you describe are a lot like the Hookers he has. We had to cut gaskets for the collectors and I fabbed up flanges for the pipes. I would do a search for pics of the Hooker headers and see if you can match them up. His car is a 71 Torino but with a different engine.
