FE Power Forums => FE Technical Forum => Topic started by: bn69stang on June 22, 2014, 06:57:53 AM
Title: vintage venum brake conversion
Post by: bn69stang on June 22, 2014, 06:57:53 AM
I found this brake that use s 2001-2004 Bullitt or cobra brakes , gives you bigger more modern brakes and lets you use 17 inch wheel s . The kit is $495.00 front and rear , then you buy rotor s and caliper s and use a 96-04 17 inch wheel .. www. vintage venum.com  , and you don t have to use any wheel spacer s . I just picked up 02 Bullitt caliper s brand new in the box loaded with pads front and rear for a $100.00 , powder coated red with the running horse on caliper , I checked on front rotor s and found drilled and slotted ones for $54.95 each .. Bud
Title: Re: vintage venum brake conversion
Post by: TomP on June 22, 2014, 12:54:47 PM
Mustang Steve also offers the brackets to adapt the newer calipers too, cheap and they work well.  Great deals on the calipers and rotors. I think the brake hoses are Metric so you need to adapt the one end to the metal line.
That doesn't ALLOW you to use 17" wheels it REQUIRES you to. :)     Some 16's may fit but need to be checked closely.
Post by: bn69stang on June 22, 2014, 02:49:41 PM
Thanks Tom i will check into that , this would be a long term project ,  lol Bud
