FE Power Forums => Non-FE Discussion Forum => Topic started by: machoneman on May 02, 2014, 06:00:50 AM
Ran across this one, and while I don't know much about them, this is one streamlined engine.
http://www.youtube.com/watch?feature=player_detailpage&v=RcLHb1Kczy8
Cool old British train. Can you imagine the rotating forces of those things moving at over 100mph? Compared to the 4"+ stroke of our FEs, those things were throwing some REAL iron around!!
The reciprocating mass of a good size steam locomotive might exceed 2000 #'s. Kind of like an entire volkswagen beetle bouncing up and down a huge stroke at 80 mph. That analogy was given to me from the crew of the restored Daylight 4-8-4 that was operating out of Portland.
I used to share office space with a British steam enthusiast, and as they are so apt to do, he took pleasure in pointing out what he thought were deficiencies in American steam design (which ended long before British so was deprived of several decades of mechanical and metallurgical development). But it always stopped him cold when asked to compare tractive force. What I knew but did not admit, was that Britain BY DESIGN didn't need a lot of tractive force in their locomotives, relatively flat country with shorter trains.
Similar arguments could be drawn between our 'primitive' but hugely successful FE engines, compared to something more "properly" (but daintily) designed.
It is a fine time for all steam enthusiasts that UP is restoring one of the 4000 series locos, considered by many to be the best of all. For train enthusiasts, that is not unlike if Ford decided to come out with a new model FE in pickup trucks.
Closer to home IF your traveling along I-95 and care to take a break to see a massive steam locomotive absolutely free just look for the Convention Center exit in middle downtown Jacksonville it's less then a 1/4mile off the highway. You guys are right I was amazed seeing what has to be 500-700 lb counterweights on each of the 6ft plus drive wheels. The connecting rods are another source of amazement . This locomotive spent the first twenty years of its long life in passenger service hauling 10 to 12 car trains at speeds of 70 to 80 mph.
http://www.metrojacksonville.com/article/2008-oct-atlantic-coast-line-1504
Vintage 1935 Casting up and milling a new BIG engine!...................Check the safety gear???????
https://www.youtube.com/watch?v=vx6hmSclbRE
