		FE Power Forums => FE Technical Forum => Topic started by: garyv on April 28, 2014, 08:34:11 AM
				Brent was finally able to get my 465 cid Tunnel Port engine on the dyno this past week.
It made 605 HP @6900 RPMs and 588 TQ @ 4700.  was making 600 HP from 6300 RPMs up and gained a few
more up to 6900 to put it @ 605.
The recipe included a Pond cast iron block, at a 4.310" bore, coupled up with a custom machined RPM 3.980" steel crank. Custom Diamond pistons on Lunati 6.800" H-beam rods. Compression ratio was right around the 10.25:1 mark. Cam was a custom Bullet solid roller, 260/270 @ .050", 106 LSA on a 104 ICL, .625/.660 lift, with Morel pressure fed lifters. Rockers are Harland Sharps on a Dove set up.
The TP heads flowed 340cfm on the intake and around 200 exh. @ 600 lift.
Could have probably squeezed a few more HP out of it with a single four intake but I wanted to keep the look of
two fours.
All the details and some pics and video were posted over on the FE forum on 4-25-14 by Brent
I am really pleased with how this turned out considering it is more of a stock Ford stroke and not a 482
and made with 46 year old heads and intake.  Performed right up there with engines with more cubes and
newer heads.
Can't wait to get this thing into my 66 Fairlane.
garyv
				Cool! I did though see your and Brent's comments on the engine maybe making more HP with a single 4-bbl than the duals.
IIRC, your duals are running about 1450 cfm or so and even a large Dominator would be hard pressed to do more than 1250-1300 cfm.  Is the OEM Ford dual intake ancient design the limiting factor here......since duals usually make more HP?
				106 LSA? That has to be one mean sounding hombre at idle! Should do pretty well at scaring some old ladies and kids too :)
As long as the carbs are set correctly, I kinda doubt you would have gained more power with a single 4 set-up. Aren't they QF carbs designed for a 2x4 induction?
So what car is this destined for? Does it have manual brakes, because I'm guessing it doesn't have a lot of vacuum at idle? Sounds like it will get you to the store and back in record time though!
				Thanks for posting on this forum, Gary.  I didn't know how many guys were members of both forums and didn't want to wear out my welcome....hahaha
Bob, I don't think the carb cfm is necessarily the issue, I think it's the intake design.  I've never really seen the case where a dual carb intake makes more power than the single carb intakes, at least not on my stuff anyway, and barring a sheet metal or tunnel ram.  I've been able to try similar combinations with both intakes have never gained horsepower with the duals.
The guy that owns the dyno shop is a big Mopar builder, and he recently dyno'd a 493 inch BBM for himself.  Tried a couple different intakes, and the single carb intake was worth 30 hp over the 2x4 setup that he tried.  Coincidentally, while talking to Robert Pond a few months ago, he told me that he tried a Tunnel Wedge on his SS motor and slowed down...
This one does sound mighty mean idling and at full song.  While dyno'ing, we had guys that would stop by and just sit in their cars outside next to the exhaust to listen to it....hahaha
				I recall a while back when Blair did that big TP motor for Fetorino they dyno'd it with
a 2 x 4 single plane and 1 x 4 and I was thinking the single carb made more power.
Maybe Jay can give more details since it was done at his place.
As far as the brakes they are non power 4 wheel discs.
garyv
				Actually I think on that one, the dual carb intake made more power, but they didn't have time to tweak on it because of dyno issues.
				Thanks Brent for the explanation!
I guess from the old days, I like many assumed that a dual intake would naturally make more hp, perhaps not much, but still more hp  in pretty much all applications. But often those old drag tests and even some dyno tests were likely flawed as they probably weren't A-B-A tests. That and a desire by the suppliers to sell more speed parts!
Come to think of it, some local FE racer pals of mine of yore did do some back-to-back swapping of from a single carb to dual carbs on both Tunnel Port and Hi-Riser stock stroke engines in a beautiful all-black '67 Fairlane.  The duals, near identical to your test, I clearly remember did not improve the e.t.'s in either case but I had always suspected Richie Migut's tranny choice as the real culprit (a 11.70ish car with a C-6 and a higher stall convertor, but certainly not optimized for either combination). Interesting to learn all these years later that he probably should have stuck to the single carb set-up and worked to optimize his convertor for better e.t.'s instead.
				Can't beat the looks of a dual carb setup though.   :)
(http://i170.photobucket.com/albums/u267/shellvalleyowner/65196D7B-3B19-481A-B59E-19F07D29C10C-40243-0000162FE787CF45_zpsfa9aab48.jpg)
				Can't say that I agree on the 4V vs. 8V thing.  Just taking the data from my book, on my 600 HP 427 sideoiler engine, the top five finishing manifolds for peak horsepower were all 8V setups.  Number six was the Edelbrock Victor with the Dominator carb.  For average horsepower from 3000-7000 RPM, the top seven finishing manifolds were 8V setups.
On my 675 HP 427 stroker dyno mule, the Victor/Dominator combo did make the most peak horsepower, but not the most average horsepower, that again went to a couple of the 2X4 setups.
Based on my experience you can usually make more power with a properly tuned 2X4 induction system.
				I dyno'd two 487 inch engines, both with the same heads, same cam (but one was 110 LSA, the other 108), same compression, same bottom end.  The only difference was that one was a Victor FE intake, ported by Joe Craine, and the other engine had a Tunnel Wedge ported by Joe Crane (both pairs of heads were ported by him as well).  The 2x4 setup had (2) 725 cfm carbs, the 1x4 had a Holley Ultra HP 950.  It made 16 more peak hp, but less torque.   The 1x4 engine was the one with the longer LSA.
Maybe your dyno is setup to feed air more efficiently into both carbs....???  I was talking to Dale, my dyno guy, about this, and he said he had never seen the case where a 2x4 made more hp, unless of course it was a sheet metal intake, or a tunnel ram.   Maybe that's the common denominator.
				On my super-gas car (452 tunnel port) the 660's were quicker than the single 1050 by about a tenth and one half to two tenths, however the 1050 was quicker in 60ft by a small amount with no other changes.
				I am certainly not a professional engine builder, but do have some experience in 2x4 setups....and I can say without a doubt that they require more work to get tuned properly. It's not hard work, just obviously more time consuming and most guys aren't really willing to spend hundreds of dollars for hours of dyno time, which is usually expensive. But I have always attributed the ability to make more power to the fact that fuel and airflow is more evenly distributed in a 2x4 setup compared to a single 4, due to the longer uneven runners inherent in the design of a single 4 intake.
I'm sure Ponds single 4 combo was optimized to the max in carb and runner design, so it doesn't surprise me that he slowed down when he switched over to a 2x4 like he did. If he had as many hours of testing, tuning and runner work invested in that 2x4 combo, I'm betting he would have gained that speed and time back.
Not that it really matters on a street engine anyway. At 600+/-hp, would you really notice if you gained 10-15hp without a timeslip? And like Brent said, you just can't beat the looks of a dual carb setup :)
				I fully agree that each scenario would take some intensive tuning.  Fortunately, I have a former Quick Fuel carb designer at my disposal.  :)  I will say that we spent more time on tuning the carbs than anything else, and that usually goes for most of the builds that I do.
Personally, I just haven't seen the dual carb manifolds outshine the singles.   It could be how the supply air is delivered, it could be me, but I haven't seen it, even on engines with the exact same parts below the intake.
Does Pond have a SS car?  If it's his stocker Fairlane, he showed up at Pomona a few years ago with a tunnel wedge on his 427 instead of the stock dual quad MR intake and his car was very fast.  The other guy running a AA/S Ford with a HR was quite a bit slower.  Don't know how he got that intake approved for stock class though.   Maybe he was comparing the tunnel wedge to the regular MR intake rather than a single 4?
(http://i151.photobucket.com/albums/s156/oldafretired/DSC_0488_zps6a217384.jpg)
I have enough trouble with a single 4 and don't want to mess with a dual quad intake.  I'm biased and prefer the look of a single quad on an FE, especially a dominator.  :)
Hey Brent, have you had a chance to test a QF 4150 style 1050 against a 1050 dommy on the dyno?
We should all be so lucky! ;D
				Sorry Earl, I meant stocker.  Next time I talk to Robert, I'll clarify to make sure, I may have misunderstood.   I do know he said that Keith worked him up a Tunnel Wedge to match his heads and he slowed down.  I may have misunderstood in what he was comparing it to.
I haven't compared a 1050 4150 to a Dommie yet, last Dommie motor I did was a 529 inch BBF with a QFT 4500 1050, but we didn't try other carbs.
				I have done several single four barrel combinations and several 2x4 combinations.  I don't have the hard data in front of me right now - but general observations are similar to Jay's.  The 2x4 usually made more steam.  In every race environment where they are legal you will usually find some variation on a tunnel ram in the top flight efforts.
				Have you done any back to backs?  2x4 vs 1x4, with the same combinations otherwise?  I've been able to do a few, and the results I have don't follow that trend, but again, it could very well be the way the dyno is set up.
I have mentioned this to Dale Meers, the builder whose dyno I use, and he said that it followed the same trend that he sees when he dynos his own stuff.  He's a big Mopar guy, and while dyno'ing his 493 inch BBM last week, he found that a single carb intake was 30 hp above the dual carb intake he had (760-ish vs 730-ish).  Similar results, same dyno, so there could be a correlation, but he builds a lot more race engines than I do, so I would expect him to have more "real world" data.
Apologies to Gary for hijacking his thread....don't want to detract from his moment in the sun.
				Speaking VERY generally, a 2X4 FE will make more steam and go faster than a single carb.  It has a huge amount to do with how much a particular engine demands.  The bigger the mill underneath, the more a 2X4 will help, as long as it is a good enough manifold.  A tunnel wedge is borderline on being too big for a 427, and it is too big for anything smaller.  I have a customer with a 511 cube roller cam FE.  We did the engine with a Victor that I modified extensively, and a 4150 that most would call a "950".  It made 820 hp and a little over 700 ft-lbs torque.  When we freshened the engine,  I did a tunnel wedge in similar fashion, and two 850's.  On the same dyno, same cam, same everything, it then made 880 hp and 770 ft-lbs torque.  A huge difference.  By contrast, I did a 445 for a nice man with a LR 2X4 and two 600's that made 580 power and just under 600 torque.  The very same combo with a RPM manifold and a 750 DP made 560 power and a tad MORE torque than the 2X4.  If we go smaller and less, the difference will be smaller and less, until we finally get to the point where the single four suits the demands the best, and then the single will win.
On heads that are too big for an engine, a smaller (single four) manifold will crutch the issue often times.  My opinion is that on the combo Brent described, he has a "mid-size" FE by today's standards, with a "too big" port, so the single four with less volume helps the "big head" problem and the single four shines.
A dual plane HR manifold with two 715's is 40 hp and no torque, better than the same engine with a dual plane and a single 780.  I did that back to back once on a 427 cube flat tappet.  The curves are different, and the single carb has better torque way down low, and falls off sooner with a different bell shape of the power curve.
It is hard to make a blanket statement about one versus two without looking at the other factors.  I did not mention T-rams for either one, but in that world, the dual carbs are absolutely better, as others have mentioned.
That should be a nice street driver at 10.25 C/R, and with that 106 cam it'll sound like John Force's funny car.
				Nice explanation Blair !
Appreciate your insight into this topic.
garyv
				Maybe I got into what Blair said I shouldnt have....generalities.
I have a degree in mechanical engineering and the first thing they teach you is that formulas and theories don't always work, so you have to go by data that youve gathered.  In my case the few instances that I've been able to do back to backs, the single has inched ahead.  Maybe it was the way the carbs were(nt) able to scavenge air...maybe the lengths of the single plane intakes favored the rpm range better, who knows....but those are my experiences.
I always try to not pass up an opportunity to gather more data, so maybe I can twist Gary's arm on a few things.... ;-)
				Dyno guys - any issues with vac secondaries opening when on the dyno?  I have never dyno'd anything other than mechanical secondaries, but have heard that some guys have to mechanically open vac sec carbs to get them to open all the way.
****Edited for misuse of the English language :)
				This has turned into one heck of a great series of posts!  Perhaps the real question here is the difference between OEM type dual carb intakes versus modern (or old) single 4 bbl intakes.
Think we'd all agree (?) that true drag race type tunnel rams, cast or sheetmetal, would out do single carb intakes.
				I'd agree with that.
				Regardless of the single vs dual Carb discussion, Brent built a heck of a street motor! 10.25 to 1 compression with a little over .600 lift should be very reliable with great manners, (valve lash etc.). Like its been stated before its fun to see something a little different than the normal all aluminum, cnc head, 500 inch race motor. That motor, in Garyv's 3400 lb fairlane, will be an animal! With fangs! And fur on it and stuff! Nice build guys.
No doubt, I have known Brent for a long while now and all of his stuff is always very well thought out.
....will be an animal! With fangs! And fur on it and stuff! Nice build guys.
I hope you aren't talking about fuzzy dice hanging from the rear view mirror...lol
Ross, I'm not a dyno guy, but the only motor I've had dynoed was the old 2x4 MR in my Mach, and it had to have the secondaries pinned open. It just wouldn't build enough vacuum on the dyno with the dual fours. Strangely, they would open just fine when in the car. I never understood why that was the case though.
Same as I heard
				Yes, to really get the secondaries to open on the dyno you often have to either put in the really light springs in the diaphrams (yellow, I think?), or pin them open.  That is really easy to do with a tie wrap that holds the secondary actuation lever to that slotted plate that it fits into on the secondary throttle shaft.  Tie wrap them together when the carb is closed, and at full open throttle all four throttle blades will be open.
				Thats odd, when we dynoed both my old 428, and the current 454, I had my "old faithfull" Sidewinder and Holley 780 vac sec carb on both engines, and the secondaries opened up fully with no additional tinkering required. I don`t see why the airflow going thru the carb on the dyno should be any different than in a car (albeit in a car with a very tall hood scoop!)
				The reason for that isn't clear to me either, and the fact that yours opened shows that its not always the case.  The dyno is loading the engine, so there really isn't any reason why the secondaries shouldn't open on the dyno.  But, often they don't...
				Sweet set up I  wish it was in my 62 with my tko 600 behind it
				We are not through yet.   Sent the heads and intake to Lawes Mayfield to see if he could improve upon them.
				Love reading this kind of stuff! I remember my Uncle playing around with his well built 440 in his boat. Came to the same conclusion (even though its a Dodge) that the T-Ram did better then the single 4 set up. I love the experience and expertise of everyone here. Well thought out ideas....JMHO
