FE Power Forums => FE Technical Forum => Topic started by: Saltshaker on March 24, 2014, 06:37:44 AM
Is it ok to use 20-30vr1 in a 428 factory crank and rods?
Jon
It'll be fine. Some good stuff below and I'm NOT that Bob ;D
http://www.bobistheoilguy.com/motor-oil-101/
10-30 in a good quality will work fine in a stock engine or even slightly modified. If the temperature rises above 80 degrees I switch to 10-40. Do not use oil that has there starburst logo on the container, the oil contains additives to prevent proper flow to the components in the combustion. I like the Royal Purple or Red Line street oils personally.
